September 15, 2026, 04:41:44 am
Hoffman Amps Forum image Author Topic: Suggestions needed for new project  (Read 6065 times)
Offline frpax
  • I have no idea what I'm doing!
« on: April 18, 2017, 08:06:16 pm »
Hi all!
I scrounged up a pawn shop find! For $20, I got an old Crate 1x15 combo. Only thing missing is the solid state amp! Perfect!! The speaker looks ok and I'll not mess with it unless I have to.
The chassis area is 3.25 inches high by 17 inches wide by 13.75" deep as it sits. I plan on lowering the chassis area in the back to accommodate tubes (about 2 inches is about all I think I'll need). PLENTY of room to do one of many things!!
I'm thinking a double ended 6L6 or EL34 design with a full tone stack. I did the Plexi 6V6 (converted to 6L6) thing before. Maybe I could redo that (only better this time) or something else. I don't think I want reverb.
Suggestions?
“Whether you think you can, or you think you can't--you're right.”
~Henry Ford
Re: Suggestions needed for new project
« Reply #1 on: April 18, 2017, 08:26:05 pm »
you mean parallel SE?
pick your favorite preamp, add the power tubes, walla!  well maybe some math to figure out PT and OT
Offline hesamadman
« Reply #2 on: April 18, 2017, 08:31:28 pm »
Just be sure to remember tube layout in reference to the already installed speaker. Especially if you get a pre punched chassis.
A 17 inch width should be plenty to get you a nice push pull pair of what you're wanting. If you want to do this all custom, you could still use a 2.5 inch high chassis but design your faceplate to be larger and cover the rest of gap in enclosure.
Offline frpax
« Reply #3 on: April 18, 2017, 08:35:20 pm »
I'm not sure what that means. I'm just wanting something in the general vicinity of 30-ish watts.
~Henry Ford
Offline frpax
« Reply #4 on: April 18, 2017, 08:39:24 pm »
The whole thing is going to have to be custom. I have access to a sheet metal bender, so I've got that going for me.
~Henry Ford
« Reply #5 on: April 18, 2017, 09:08:16 pm »
Single ended (SE), as apposed to push-pull(PP)
you probably won't get there with PSE unless you have lots of tubes n like the sound :icon_biggrin:
Offline frpax
« Reply #6 on: April 18, 2017, 09:20:08 pm »
I need to learn more of the lingo! All I know is that it takes 2 6L6's or EL34's to get the headroom I want.
~Henry Ford
Offline frpax
« Reply #7 on: April 19, 2017, 04:10:16 pm »
I'm leaning towards a Bassman 5F6-A circuit....  :dontknow:
~Henry Ford
« Reply #8 on: April 19, 2017, 04:54:52 pm »
Really wanna learn?
Buy this book and build that amp and learn more than you could ever possibly absorb.
https://www.ampbooks.com/mobile/books/bassman/
