September 16, 2026, 12:04:15 am
Hoffman Amps Forum image Author Topic: Is this an improvement to virtual earth on heaters PS ?  (Read 4415 times)
« on: April 24, 2017, 06:06:59 am »
I've seen this schematic and I would like to know if it worth to apply it on guitar amp circuits
a 20K pot will not require to be a high W rated unit because of the small current crossing it (also if paralleled with 2 x 10K resistors)
« Last Edit: April 24, 2017, 06:09:29 am by kagliostro »
Re: Is this an improvement to virtual earth on heaters PS ?
« Reply #1 on: April 24, 2017, 11:00:15 am »
That is said to be for "direct heated" tube. None of our usual g-amp tubes are direct heated.
Even used as claimed, it makes no sense. The cathode current must flow in several K Ohms of variable resistance, much more resistance than we usually put in a cathode return.
I think someone didn't think about it.
6.3V in 500 Ohms is less than 0.1 Watts.
« Reply #2 on: April 24, 2017, 11:21:47 am »
Thanks for the answer PRR
