August 29, 2026, 08:27:26 pm
Hoffman Amps Forum image Author Topic: AC30C2 help  (Read 39661 times)
Offline shawn w
AC30C2 help
« on: May 02, 2017, 11:09:03 pm »
Hi,
I was referred here for some possible help. I picked up a Vox AC30C2 amp super cheap, but needs some help. All fuses are good and both the standby and power lights come on. The R108 resistor is burnt. On visual inspection, it appears that this is the onky thing that's wrong. This goes to what i think is the G1 pin. I have limited experience with the hard electronics of a tube amp and diagnosis, but could it be that simple that this one resistor is bad ? Could it be a bias issue?
Thanks in advance for your advice,
Shawn
Re: AC30C2 help
« Reply #1 on: May 03, 2017, 12:07:05 am »
Burned resistors usually indicate something else has failed. Can you provide a schematic? What are the amp symptoms?
Re: AC30C2 help
« Reply #2 on: May 03, 2017, 11:23:34 am »
R108 is part of the buffer op amp circuit for the FX return. IC101 is probably cooked. If you jumper the FX send-return jacks with a short cable, what happens? (Does the amp work with a purely dry signal - incl reverb switched off?)
Re: AC30C2 help
« Reply #3 on: May 03, 2017, 01:49:04 pm »
I looked at that schematic. It's highly unlike that R108 in that FX loop burned. I suspect that is either not the correct schematic or R108 is not the correct part designator. Either way, we don't have enough info to do more than guess.
Re: AC30C2 help
« Reply #4 on: May 03, 2017, 02:13:13 pm »
Doug has the schematic
http://el34world.com/charts/Schematics/files/Vox/Vox_AC30C2.pdf
As far as I can not find R108, in the scheme i see R107 and R109 but not R108
R108 is the grid stop resistor of V7
« Last Edit: May 03, 2017, 02:34:14 pm by kagliostro »
Re: AC30C2 help
« Reply #5 on: May 03, 2017, 06:32:38 pm »
It is hard to see how this R108 could burn. Some other resistor should burn first.
Re: AC30C2 help
« Reply #6 on: May 03, 2017, 07:38:40 pm »
Ah right. There's one-too-many 'C's. Oops - Talk about Confusing LoL
If it was too much current through the control grid, then there could be something like a plate-to-grid (or screen-to-grid?) short in that output tube, or something messed up/shorted at the grid pins. I wonder if the screen resistor on that socket is also cooked/open?
« Last Edit: May 03, 2017, 07:44:16 pm by tubeswell »
Offline shawn w
Re: AC30C2 help
« Reply #7 on: May 03, 2017, 08:20:31 pm »
I want to thank you all for your responses. You have a great community here. I looked at that first print also, but couldn't see how this tied into the effects loop, so as looking a little more I found the second print posted. I'm sure it's that one.
Looking closer tonight after I took some photos (which I found out are too large to post here) I see that the other four corresponding resistors  (R101,R81 and R61) are all bad too.
Thanks again,
Shawn
Offline shawn w
Re: AC30C2 help
« Reply #8 on: May 04, 2017, 12:44:02 am »
Re: AC30C2 help
« Reply #9 on: May 04, 2017, 05:22:25 am »
Someone "flip" J31?, insert tubes 1 pin Off?, spill Beer?
Re: AC30C2 help
« Reply #10 on: May 04, 2017, 05:54:09 am »
...... I couldn't figure out how to get one sized right for here
You can upload it here http://imgur.com
for free and without registration
then use the <image TAG> and insert the link of the image
the image TAG is the small icon with Mona Lisa you find under the Bolt TAG when you post a message, this icon
this way the image is shown on the browser correctly also if it is very big
there is also an easy way to show it smaller (amount at your choice), if you want
« Last Edit: May 04, 2017, 05:58:41 am by kagliostro »
Offline shawn w
Re: AC30C2 help
« Reply #11 on: May 04, 2017, 11:58:04 am »
Could be? I bought it like this, so who knows what the real story is. I have a grand total of $90 in it, so I figured for that at least I'd end up with two Greenbacks if nothing else!
Thanks for the tips on the photos, too.
Shawn
{edit- dangling /quote fixed --PRR}
« Last Edit: May 04, 2017, 04:58:03 pm by PRR »
Re: AC30C2 help
« Reply #12 on: May 04, 2017, 12:29:28 pm »
With the power transformer on, are you getting any AC voltage across each pair of PT secondaries?
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: AC30C2 help
« Reply #13 on: May 04, 2017, 03:20:40 pm »
It almost makes me think someone did something stupid with the transformer wires and connected them up wrong or accidentally shorted something physically.  I agree, looking at that schematic, I have no clue how those resistors would smoke!  There are multiple other resistors in line between them and the PI side, and the other side is the tube.  Could one tube somehow go bad so that it conducts full current through the input grid and passes that out through all the other input grids I guess?  That seems unlikely, but I don't know all the failure modes of a tube.
~Phil
Phil Davis
tUber Nerd =|D
Offline shawn w
Re: AC30C2 help
« Reply #14 on: May 04, 2017, 04:22:30 pm »
I'll have to check that. Maybe tonight I'll dig in a little deeper and see if anything jumps out at me.
~Phil
I wondered the same thing. My knowledge is a bit limited, so this is definitely a learn as I go experience.
Shawn
Re: AC30C2 help
« Reply #15 on: May 04, 2017, 05:06:11 pm »
Too-too odd.
One end of these goes in the power bottle, and bad things can happen. G2 breaks loose and hits G1, fer example.
However that current has to go TO somewhere. All the paths I see are through 220K or more, or 10K and a cap. Even taking 3K in series with 10K, the 10K will get 3/4 of the voltage and burn-up 3 times faster. That's for same-size parts. I suspect the 10K is a small part and the 3K looks like a bigger part.
I could *imagine* a G2-G1 short in one tube and the usual G1-K conductance in its partner. That could give maybe enough current to toast both resistors (and both G1s). But for this to happen both sides of a quad? Ah, maybe after the first death the user swapped tubes around and invoked the same smoke on the other pair.
I would presume all four EL84s are "sick" until you prove otherwise. Replace the bad resistors and sniff for more. Install known-good EL84, maybe just one pair at a time. Keep the windows and doors open until you are sure the smoke has stopped.
Re: AC30C2 help
« Reply #16 on: May 05, 2017, 06:08:27 am »
Ya, that's where my J31/J33 comment came in, poor design IMO.  Crud under, swapped, arc'd, Tube failure that get's shared:)
Offline shawn w
Re: AC30C2 help
« Reply #17 on: May 05, 2017, 06:10:09 pm »
Thanks again for all the guidance and direction. I've got a whole set of tubes on the way, will pick up some new resistors a day go from there. I'll let you know if I find anything else.
Shawn
Offline shawn w
Re: AC30C2 help
« Reply #18 on: May 12, 2017, 10:12:05 pm »
So I'm going to pick up some resistors this weekend, but I can't seem to find a schematic that recommends the wattage rating?  Any suggestions?
Thanks again,
Shawn
Re: AC30C2 help
« Reply #19 on: May 12, 2017, 11:43:23 pm »
Replacing the ones that burned up? 1/2 watt will be big enough provided the weird problem that burned then is gone.
Offline shawn w
Re: AC30C2 help
« Reply #20 on: May 13, 2017, 02:37:41 pm »
Thanks. 1/2 watt it is.
shawn
Offline shawn w
Re: AC30C2 help
« Reply #21 on: April 29, 2018, 09:18:06 pm »
Ok,
So I know it's been a while, but i finally got around to replacing those resistors. I put all new preamp and power tubes in it, put it on standby and fired it up. Power light comes on and the power tubes all glowed nicely. No burnt up resistors! So I switched off the standby. The standby light comes on. It made a humming noise and popped the F1 fuse.
So any suggestions as to where to look next?
Shawn
Re: AC30C2 help
« Reply #22 on: April 30, 2018, 05:32:51 am »
...So I switched off the standby. The standby light comes on. It made a humming noise and popped the F1 fuse...
Probably a shorted filter cap
Offline shawn w
Re: AC30C2 help
« Reply #23 on: April 30, 2018, 01:55:20 pm »
Would that be C10,C20 and C58?
Thanks!
Shawn
Re: AC30C2 help
« Reply #24 on: April 30, 2018, 05:07:37 pm »
It should be obvious when you look, but if it didn't explode any or all the ones I circled in red.  All the things I circled in blue need to be measured VDC to ground once you quit blowing fuses
Offline shawn w
Re: AC30C2 help
« Reply #25 on: May 01, 2018, 12:02:40 am »
Thanks! I'll check those out tomorrow.
shawn
Offline shawn w
Re: AC30C2 help
« Reply #26 on: May 01, 2018, 10:48:21 am »
So I checked and didn't see anything obviously bad or burnt. I took a few pics. Maybe someone see' s something I don't. Thanks again for the input!
shawn
https://imgur.com/gallery/AKTaRFz
Re: AC30C2 help
« Reply #27 on: May 01, 2018, 12:03:30 pm »
the pic that shows 3 ecc83, 2 caps and a rectifier, is that just grainy image, or is the board that grubby?  If it's that grubby, the dust/dirt can create nice arc potential.
Is it still popping fuses with tubes in?, with all tubes out?, IF so, OHM (NO POWER) each of the blue circles to ground, they each should be many hundred or thousands ohms "charging" (increasing in ohms)
Offline shawn w
Re: AC30C2 help
« Reply #28 on: May 01, 2018, 08:57:36 pm »
I didn't try it with tubes out. So I should take all the pre and power amp tubes out, turn it on and turn off the standby and see if the fuse goes?
I'm having trouble posting the photos. Yes , it is dusty lol.
http://imgur.com/a/AKTaRFz
Hopefully this gets all the pics.
shawn
Re: AC30C2 help
« Reply #29 on: May 02, 2018, 08:58:19 am »
yup.  the tubes are the main source for current draw, without them in the fuse should live long time.
IF the fuse blows without tubes, unplug, NO power, and ohm to ground the blue circles
Offline shawn w
Re: AC30C2 help
« Reply #30 on: May 02, 2018, 11:02:45 am »
Perfect. I'll give that a shot when the new fuses show up. Thanks again for your help.
shawn
Offline shawn w
Re: AC30C2 help
« Reply #31 on: May 06, 2018, 06:32:54 pm »
Ok, so new fuse in it, pulled all the new tubes and powered it on. Got the red on light. Turned the standby off and got the green light. I left it on for quite a while without any fuse failures. With the standby off, you can hear a slight hum from the speaker. Very slight. Turn it on standby and the hum stops. Interesting note, when I turn it on standby, the green light stays on. When it's initially powered up, the green standby light is only on when the standby is turned off.
So where to now? Lol
Thanks!
shawn
Re: AC30C2 help
« Reply #32 on: May 06, 2018, 06:49:09 pm »
I'll take a look at the pwr/stby, it would help me saying something like standby switch open, (or closed), standby on/off messes me up  :laugh:
the green light might be staying on because the caps haven't discharged  :dontknow:
plug in all the tubes EXCEPT the EL-84's and see if you sacrifice to the fuse god
Re: AC30C2 help
« Reply #33 on: May 06, 2018, 07:14:44 pm »
Homework, on page 3 of my schematic just below D13 is a reference to R+2, try and find the other end
of R+2 on your copy, I gave up
Re: AC30C2 help
« Reply #34 on: May 06, 2018, 07:17:20 pm »
OK, I didn't, looks like R should be B based on the R values below it, go, blow a fuse  :laugh:
Offline shawn w
Re: AC30C2 help
« Reply #35 on: May 06, 2018, 08:13:00 pm »
You're correct on the standby light. If I left it sit a bit, the caps discharge and the light goes out. I know what you mean about standby  on/off. I was trying to figure out the best way to word it lol.
So with all 3 preamp tubes in, no blown fuse. I powered it up 3 times and nothing blew, caught fire or exploded.
shawn
Re: AC30C2 help
« Reply #36 on: May 06, 2018, 08:25:45 pm »
go look at reply 24, measure the blue circles, clip your - lead to chassis, put one hand in your pocket, measure, record and post the VOLTS DC.
there's not much load, but enough to spot something  :dontknow:
Offline shawn w
Re: AC30C2 help
« Reply #37 on: May 06, 2018, 09:29:51 pm »
So I'm a bit of a newb at this. Am I following the trace on the board to where the plug is and.checking there? What kind of voltage should I see? I'm probably going to need a new multimeter.
shawn
Re: AC30C2 help
« Reply #38 on: May 07, 2018, 08:53:01 am »
you might want to hunt up an experienced buddy to help out then, your DCV should be stable, north of 300vdc at B+1, dropping as you move down the line.  the caps circled in red, positive side, is a great place to get each voltage.
and ya, make sure we don't whined up chasing a bad meter.
Offline shawn w
Re: AC30C2 help
« Reply #39 on: May 07, 2018, 01:54:34 pm »
Ok. New multimeter will be here tomorrow and I'll check those. I do have some experience, I just want to make sure I'm checking the right spots. Getting to the back side of that board is going to be a pain, lol.
Thanks!
Shawn
Re: AC30C2 help
« Reply #40 on: May 07, 2018, 03:02:13 pm »
I've worked on 2 of those, one I fixed, one was to damaged to even bother, working the amp is fine, but it's a POS from a quality assembly point of view.
you should be able to find a place on the parts side to measure, look at the schematic page 3, find the Resistor that goes to the cap, like R120, that gets you both B+1 and B+2, R74 gets B+3............
moving the board a lot will only invite gremlins in, we want to avoid them, or chase them away  :icon_biggrin:
Re: AC30C2 help
« Reply #41 on: May 07, 2018, 03:25:14 pm »
I prefer the references AC switch and DC switch when Standby is present.  This eliminates me trying to clarify.
Offline shawn w
Re: AC30C2 help
« Reply #42 on: May 07, 2018, 09:34:15 pm »
By looking at the schematic, that's what I was thinking so thanks for confirming my thought. I'll let you know what I find.
shawn
Offline shawn w
Re: AC30C2 help
« Reply #43 on: May 12, 2018, 10:11:45 pm »
So with new tester I hand I checked for voltages at the resistors listed below. It changes slightly from one side of the resistors to the other, but nothing more than a couple volts. This is what I saw-
R74 - 385v
R22 - 380v
R15 - 379v
R106 - 28-34v (left and right sides)
R103 - 29.5-35v (left and right sides)
R120 - 385v
It took me a minute to figure out R120. There's a callout spot on the board, but nothing there. Not even holes where it would be. I figured out the resistor was on the other side of the board, with just the solder points showing lol.
shawn
Re: AC30C2 help
« Reply #44 on: May 13, 2018, 09:35:44 am »
stay on page 3, verify that to 50 ohm cathode R is close to 50, ohm out the 470 R's that go to the screen grid r79, r95.....  If they ohm good, pick your favorite fuse, put it in, put in the PA tubes and knock on wood, throw the switch
Offline shawn w
Re: AC30C2 help
« Reply #45 on: May 13, 2018, 11:55:43 am »
Perfect! I'll give that a shot and let you know what I find.
shawn
Offline shawn w
Re: AC30C2 help
« Reply #46 on: May 13, 2018, 05:53:38 pm »
So I checked the resistors. Here's the results-
R79 - 466
R95 - 466
R104 - 466
R117 - 465
R119 - 51.5
So I put a new fuse and lit the power switch. All tubes glowed nicely. I moved the stand by switch to rock n roll and...... loud hum. Popped the fuse.
These are new power tubes. I haven't tested them individually. Should I try one tube at a time to see if I can isolate the issue?
Thanks again so much for your time and help!
shawn
Re: AC30C2 help
« Reply #47 on: May 13, 2018, 06:39:19 pm »
Look on page 1, see the “points” OP + and OP -  (top of R113, and bottom of R116)
Go to page 3, see where they come in, through J31, where your original R’s were toast.
Got it, pull all the power tubes, clip 1 meter lead at R113, then, measuring ohms (NO power), put the other probe in pin 2 socket, tube side of V4, record value, repeat for V5, 6 and 7
Then repeat using R116, all 4 tubes pin 2
NOTE the schematic, page 3 shows 2 OP –   :cussing: so it's a crapshoot! you should have 2 readings  measuring around 3.3k and 2 readings measuring ????  from each R113 and R116
Offline shawn w
Re: AC30C2 help
« Reply #48 on: May 13, 2018, 08:45:26 pm »
So here's what I measured, going left to right (4-7)
R113 - 3.2, 3.2, 5.5, 5.5
R116 - 5.5, 5.5, 3.2, 3.2
shawn
Re: AC30C2 help
« Reply #49 on: May 14, 2018, 10:21:56 am »
forgot last night to have you ohm all the PA tubes pins to ground also, so put the - on chassis, and ohm each socket pin, tube side, to ground.  something in your PA is drawing way more current than design spec'd.
do you  have a 5k 10 watter, maybe 2 10k 5watters you can put in parallel laying around?  how bout 20 - 100uf 400+vdc caps?
once you get those measurements, put all 4 tubes back in (NO power) and ohm from B+1 to ground (right side of R120 pg3)
***EDIT*** make sure you indicate ohms, K ohms, Meg ohms, guessing your 3.2 is really 3.2K?
