September 14, 2026, 10:19:16 pm
Hoffman Amps Forum image Author Topic: Can't get bias below 48ma on my Princeton clone  (Read 4738 times)
Offline Imntgrumpy
« on: May 03, 2017, 06:24:35 pm »
Hey gang,
My Hoffman Princeton Clone started to sound distorted and farty after 6 years of use.  Just replaced every tube and tried to adjust the bias.  Well, I can't seem to get it below 48ma.  I've already installed two 100k-3W resistors in series for my "range resistor"  (didn't have the right value available).  The original schematic calls for only 1 100k-3W.
Looking for suggestions on taming the bias.
Jim Koehler
Long Island, NY
Re: Can't get bias below 48ma on my Princeton clone
« Reply #1 on: May 03, 2017, 06:35:46 pm »
Exact schematic used would help.
My blunt guess is that the bias supply is failing, perhaps a leaky cap. So where you want -50V, you only got -30V now and zero next week (infinite 6L6 current).
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #2 on: May 03, 2017, 08:08:38 pm »
Hi buddy, I don't know your level of knowledge and maybe you've already tried what I am suggesting you to do:  remove the power tubes, fire the beast and check the bias voltage. Try to get at least -50V at pins 5 if not, replace the bias related parts: diode, cap and resistors. While you're in there, install a pot for bias adjustment and a 1 OHM resistor from the K to gnd. Check also the two 220K ( maybe 100 or 330K ) grid leaks resistors. Like PRR said, try to post a schematics.
Colas
P.S.: call me Alvin.
Offline Imntgrumpy
« Reply #3 on: May 04, 2017, 09:12:18 am »
Fixed!   :laugh:
Removed one of the 100k-3W range resistors and was able to adjust the bias to 29ma.
  • MAKE LOVE NOT WAR
« Reply #4 on: May 04, 2017, 09:18:05 am »
Excellent, now you can play !
