September 14, 2026, 01:27:46 pm
Hoffman Amps Forum image Author Topic: 6G6 Bassman bass channel resistor?  (Read 4765 times)
Offline punkykatt
« on: May 10, 2017, 10:43:28 am »
The 6G6 Bassman,  the bass channel has a 1m resistor across the plates of valve 2. What is the purpose of this resistor?  Thanks Punky
http://el34world.com/charts/Schematics/files/fender/Fender_bassman_6g6_schem.pdf
Re: 6G6 Bassman bass channel resistor?
« Reply #1 on: May 10, 2017, 10:56:36 am »
That's a local negative feedback resistor. Don't think of it as a resistor connected across the two plates even though it really is. Think of it as a resistor connected from the plate of a triode back to the grid of that same triode. It has to connect through a coupling cap to block the dc voltage from reaching the grid. Rather than use a separate cap Fender just used the existing .05µF coupling cap.
So, resistor from plate (output) back to grid (input) equals negative feedback.
Offline punkykatt
« Reply #2 on: May 10, 2017, 11:59:14 am »
Thank you sluckey,  I see it now.
