September 08, 2026, 01:01:37 pm
Hoffman Amps Forum image Author Topic: Telecaster selector switch wiring  (Read 6016 times)
Offline pbman1953
« on: May 16, 2017, 04:44:45 pm »
Hi
I'm trying to help a friend wire up a Telecaster 3-way pcikupo switch
Here's the switch type.
https://cdn.shopify.com/s/files/1/0657/6821/products/bajaao_3_way_pickup_selector_31d76f5b-824a-4a11-ac1f-5ad6f58a4a68.jpeg?v=1482212684
The pickups are traditional- Lipstick and bridge.  Each pickup has 2 wires each- + & - All other wires are grounds
Thanks for any help
Re: Telecaster selector switch wiring
« Reply #1 on: May 17, 2017, 01:24:50 pm »
Should be like this
« Reply #2 on: May 17, 2017, 01:27:12 pm »
There are other ways, but this is the most common.
You can add a treble bleed also which is nice on the Bridge of a Telecaster.  Check out http://www.stewmac.com/Pickups_and_Electronics/Components_and_Parts/Capacitors_and_Resistors/Golden_Age_Treble_Bleed_Circuit.html
Offline pbman1953
« Reply #3 on: May 17, 2017, 01:28:15 pm »
Thanks Ed!!
You should of seen the mess I cleaned up. The treble pot wasn't even connected. I'll finish it tomorrow night
Offline pbman1953
« Reply #4 on: May 17, 2017, 01:29:36 pm »
Thanks for the mod, I'll tell the owner the option.
