September 14, 2026, 12:39:37 am
Hoffman Amps Forum image Author Topic: Planning PT for tube w low voltage G2 request - Is this rectify schem correct ?  (Read 7045 times)
Planning a new transformer for a circuit where the Power Tube require a lower voltage than B+
Think to tubes like GU50 - EL500 - 807 and so on
A tap to the correct AC voltage is planned on the PT and ....
is correct this rectify plan ?
« Last Edit: May 25, 2017, 05:38:32 am by kagliostro »
Offline chocopower
I´m using this.
« Last Edit: May 25, 2017, 04:28:01 pm by chocopower »
David
Ciao David
Unfortunately, for me the link didn't work  :dontknow:
This is a theory intensive question on Transformer & circuit design. I believe your proposed circuit, with a tap, will function.  You could go UL; or separate PT winding; or some circuit to drop B+ to the screens.
 FWIW:  The Stromberg Carlson APH-1100 is a 100W mono PA power amp, using PP KT88's:  600V plate, 300V screen.  It accomplishes this with a separate screen winding on the PT (not a tap).  (It also uses voltage doubling on both the plate & screen supplies.)  It sounds great for hi-fi with 5% THD @ 100W; 2% THD at 80W, from 20 - 20,000 Hz.
see attached - g2 node (C3) will be approx 1/2 B+ node (C1). the example attached was designed for a pair of 6550. plates are 520V and g2 is 260V.
--Pete
Or without the frills, just this.
Many thanks to ALL
I belive all of you is right
I'm just arrived at home and walking around I was thinking to the circuit
If the G2 voltage is to be 1/2 of B+ I'll accomplish with you about the use of the CT as the G2 supply, like in this old Philips PA amp
But in some cases datasheet council is different, so an 807 at 350v B+ is to have 250v G2 and only 200V G2 if B+ is 500V
If I use a "standard" PT we have largely discussed how to obtain the needed voltage (PRR planned for me a Mosfet circuit to lower B+ to the exact G2 requirement)
But if I build my own transformer why not use a specific plan ?
So, walking, I've think to this solution (the previous I posted put on me the idea it is unsafe)
Do you think this will be the right way to have G2 and B+ independent values forom each other ?
p.s.: Jjasilli the Stromberg Carlson APH-1100 schematic is missing on Doug's database
if you have it, please post it so he can add it to the database
« Last Edit: May 25, 2017, 11:32:27 am by kagliostro »
That will work.
Since G2 power is much less than P power, it may make sense to just have dedicated windings. Especially if you wind your own. Then you can change the turns on the G2 winding without re-thinking and re-winding the P winding. Some of the big Ampegs did it this way. (VT40 with distortion feature)
If I understand correctly you PRR
you say that I can use a "sum" of the two windings voltages to supply the Plates
or have two windings that can feed, one the G2 and the other the Plate, without the necessity to stack them
100v + 200v staked
or
100v and 300v completely separated
Correct ?
You remembered me also Hiwatt has a similar circuit
« Last Edit: May 25, 2017, 11:43:13 am by kagliostro »
p.s.: Jjasilli the Stromberg Carlson APH-1100 schematic is missing on Doug's database . . .   if you have it, please post it so he can add it to the database
Here's the whole service manual including schematic. I find these old manuals to be very instructive.
I've not been successful at getting Doug or other sites to post this schematic.  Maybe someone can get it done.
I have other Stromberg Carlson materials.  But, this is the best site for Stromberg Carlson:  http://www.audiophool.com/ with lots of other things, including references to sites for transformer design & theory which may interest you.
Many Thanks Jjasilli
Now I think Doug will add it to the database
Offline chocopower
Ciao David
Sorry. Try now.
David
OK David
now I can see, thanks
