August 29, 2026, 03:03:05 pm
Hoffman Amps Forum image Author Topic: Sorry, just now found a need and interest for VVR. have Question  (Read 10282 times)
Offline madnis
I would like to use this VVR but noticed It refers to a TIP147 and shows a
part pic of a NPN device. Am I missing something? shouldn't it be a TIP142?
The pic looks like it's straight out of Valve Wizard. ( I don't have Merlins book )
my last reply moved to here with corrected parts on diagram
Re: Sorry, just now found a need and interest for VVR. have Question
« Reply #26 on: June 12, 2017, 03:05:42 pm »
Without changing the 100 ohm resistor in the circuit I tried the pot adjust again and to my surprise found it varied ~65 VDC! I can now go from 415 B+ to 350.So I'd say the circuit worked just fine for me.
Lowers all the B+ rail.
I'd encourage anyone to give it a try.let me know if YOU have different results.I'm HAPPY and only out the cost of correct part.$1.23
« Last Edit: July 06, 2017, 03:34:02 pm by madnis »
« Reply #1 on: May 29, 2017, 02:15:43 pm »
There is a considerable amount of information on VVR's and cathode biased amps in ARCHIVES:
http://el34world.com/Forum/index.php?topic=6899.0
Maybe something in there will be useful in answering your question.
« Reply #2 on: May 29, 2017, 02:20:28 pm »
yes
« Reply #3 on: May 29, 2017, 03:58:14 pm »
That circuit is planned to be used between the CT (of a PT) and Ground
So .... where is the error, is wrong the label (TIP147) or is wrong the NPN simbol ??
(Solid State is very difficult for me ....)
« Reply #4 on: May 29, 2017, 05:21:59 pm »
wrong the label
The "arrow point" typically points in the more negative direction
a tip 147 is PNP
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #5 on: May 29, 2017, 07:25:24 pm »
The part number (label) is incorrect and the NPN symbol is correct.  Disregard the ground symbol and look at the direction of the current.  The conventional current goes into the Collector and comes out of the Emitter, which makes the Collector end positive and the Emitter end negative.  This is the way that an NPN transistor is connected.  A PNP transistor would have the Emitter connected to positive and the Collector connected to negative.
Offline Tony Bones
  • Thread Killer
« Reply #6 on: May 29, 2017, 08:35:04 pm »
The thing that's confusing about dropping volts at the CT of the power transformer is that the CT ends up being more negative than ground. So, as far as this little circuit is concerned, ground is the 'positive rail' and the CT is the 'negative rail.'
Should the transistor be NPN or PNP? To answer that question, look at where the base referenced to. In this case it's the negative rail (a.k.a. CT.) That means you need a NPN transistor; TIP142. Connect the emitter to the CT and the collector to ground.
The drawing shows the wrong part number, but is correct otherwise.
(When I first wrote this post I came to 'the other' conclusion based on a different arrangement of this basic circuit. On closer examination I realized I was wrong and edited the post.)
« Last Edit: May 29, 2017, 08:45:54 pm by Tony Bones »
« Reply #7 on: May 29, 2017, 09:41:14 pm »
NPN - Not Pointing iN. and how i was taught to remember it in trade school - for bipolar devices. FET's are reverse.
Offline madnis
« Reply #8 on: May 30, 2017, 12:09:29 am »
Thanks, all who replied.
I appreciate prompt reply
and the help.
Thanks Tony B., that helped a lot.
Well I ordered the wrong part
and... did it before I looked closer
and saw the discrepancy. So off
to Mouser I go again :sad2:
______________________________________________
Has anyone used this design I
like it but...?
Again, Thanks all.
My apologies to senior members who responded.
I didn't provide much more than the question.
Yes, I did extensive research in the archives here
and looked at other sites on the subject info before
asking my question. yes new to using this forum. I
go by ?mark else where.
It's cathode biased. I've got a higher B+ over all so want to lower all across the board. My choices lower PT sec. with different PT, don't have or drop in Zener(s) at tap. I wanted variable so...
Thanks Franco didn't see the Akins in my search, thank you.
« Last Edit: May 30, 2017, 12:17:49 pm by madnis »
« Reply #9 on: May 30, 2017, 12:27:21 am »
Long time ago a friend tried that circuit without success
Now I can think that the problem was the wrong transistor
« Reply #10 on: May 30, 2017, 12:50:55 am »
Re-draw it as Plus Up.
As connected, the transistor must be an NPN (and by the values, probably a Darlington).
I still have doubts about this plan. But it is late, I need sleep.
« Reply #11 on: May 30, 2017, 03:33:37 am »
On my archive I've find also this
Download for full resolution
From Aiken Amplification
Offline madnis
« Reply #12 on: June 05, 2017, 12:53:56 am »
Ok TIP142 used and circuit installed.
I now have 354 VDC at 1st cap,(instead of 425 VDC.)
and overall rail voltages in range. 351 VDC at anode, 300 VDC
at screens and 325 VDC anode to cathode on a pair of tung sol 6v6gt.
But...not much variable. I can only change B+ ~5 VDC
down from 354 VDC. I was hoping for a variable from 425 VDC down to
350 VDC or so. My ignorance is showing.  :dontknow:
« Last Edit: June 05, 2017, 01:04:49 am by madnis »
« Reply #13 on: June 05, 2017, 01:57:35 am »
that circuit does not work. consider using the dana hall VVR.
« Reply #14 on: June 05, 2017, 02:28:56 am »
A possible variant on the use of a VVR is to feed with it G2 of the power tubes instead of the plates (less stress on the mosfet due to the lower current)
https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control
https://www.tube-town.net/ttstore/Kits/Power-Supply/Kit-TT-VoCoM-Variable-Voltage-Regulator::5651.html
« Last Edit: June 05, 2017, 02:34:02 am by kagliostro »
« Reply #15 on: June 05, 2017, 07:24:56 pm »
> not much variable.
That was my suspicion. The author is usually spot-on, but this seems to have got by him. (Or it is a trap for people who don't buy/read the book?)
Merlin is a member here.
« Reply #16 on: June 05, 2017, 08:35:39 pm »
> not much variable.
if you make the 100R a 470R or thereabouts it's like a switch - full on ~40V drop or full output with about 5% sweep of the pot.
Offline 2deaf
« Reply #17 on: June 05, 2017, 11:44:43 pm »
Member Merlin is THE Merlin?  I thought it was just some guy who took that name before Merlin could.  Had I known that it was Merlin himself, I might have asked for a clarification instead of proclaiming he was wrong in some past thread.
Offline madnis
« Reply #18 on: June 06, 2017, 01:10:25 pm »
Since I'm the one who brought Mr. Blencowe's name into this discussion,
I feel the need to clarify. I had no knowledge of whose circuit diagram I was using. To me it looked like every diagram I had seen in Mr. Blencowe's book and I made the mistake of saying so. My apologies to all.
... Every circuit design I have "lifted" from Mr. Blencowe’s has been correct in theory and in application. I've been VERY happy with what I've used from his knowledge.
To the circuit at hand. Upon closer inspection, I realized it was dubious in its depiction of a part number and its orientation in the diagram. I thought I'd ask all of you if you might concur and offer suggestions on using it based on experience with it.
Thanks to all who replied.
I've gotten my answer and
greatly appreciate the help.
Sorry about any confusion.
« Last Edit: June 06, 2017, 01:18:29 pm by madnis »
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #19 on: June 06, 2017, 07:19:35 pm »
It is possible that came from his power supply design book that he refuses to reprint until he can do a major rewrite.  He said something on his site about it having quite a few serious problems he needed to rectify before he releases a second edition.  Hopefully he's on that now, as he released a HIFI preamp book recently, and now maybe he will go back to that old topic ;).  I have the tube preamp book and love it, but don't recall if it contained that, but seems unlikely.  I too think that it looks like his format.  He sent me some of his files he uses in the tube books so I can create some images for planned videos on my youtube channel, he's super helpful and very nice.  I don't know if he'll respond here, I've only seen him chat up once or twice in the year or so I've been on.
~Phil
Phil Davis
tUber Nerd =|D
Offline madnis
« Reply #20 on: June 07, 2017, 02:21:54 am »
Thanks Phil,
I posted my own re-draw.
with part # used and pin-out.
As suggested, (but not tried yet)
I'll try the 470R instead of 100R.
for more voltage variance.
« Reply #21 on: June 07, 2017, 06:59:04 am »
That's where it came from. Page 214
    • Daviszone
« Reply #22 on: June 07, 2017, 12:42:36 pm »
Oh sure rub it in, I'm guessing that means you have one :(  I WANT ONE :P  I need merlin to get busy on that revision 2 stat
lol
~Phil
Phil Davis
tUber Nerd =|D
Offline madnis
« Reply #23 on: June 07, 2017, 12:51:26 pm »
what he said,
dido.
« Reply #24 on: June 07, 2017, 12:52:25 pm »
Don't hold your breath on that one. He said on his site "Fortunately, all the best material from the power supply book can now be found in the final chapter of my hi-fi preamps book!"
    • Daviszone
« Reply #25 on: June 07, 2017, 05:13:08 pm »
Oh I didn't realize that part, maybe I do need to just buy that one.  I'm not as interested in the HIFI side of things personally, but I guess I may learn more about tubes in general by reading that too.
~Phil
Phil Davis
tUber Nerd =|D
Offline madnis
it varied ~65 VDC!
Lowers all the B+ on rail.
 :icon_biggrin:   I'd  encourage anyone to give it a try.
$1.23
« Last Edit: July 06, 2017, 03:14:02 pm by madnis »
