September 14, 2026, 06:47:44 pm
Hoffman Amps Forum image Author Topic: Adjustable Negative feedback  (Read 5805 times)
Offline pbman1953
« on: May 31, 2017, 09:16:58 am »
From the help of Ed, I'm using a 250K pot for an adjustable Negative feedback instead of R39 (100K). When maxed the sound is very hard (harsh)  but focused. Should I decrease the pot value?
Re: Adjustable Negative feedback
« Reply #1 on: May 31, 2017, 09:23:38 am »
Ed always uses a 100K linear with a locking nut in this type of circuit and I will bet you just used what you had on hand.  So you can either change the pot, don't turn it up high enough to make it harsh or hang a resistor across lug 1 and 3 to achieve the maximum adjustment you wish.  Your choice.
Offline MakerDP
« Reply #2 on: June 02, 2017, 01:54:26 pm »
I do mine on a push-pull switching pot so it can be defeated altogether as well.
« Reply #3 on: June 02, 2017, 02:00:16 pm »
work around: put a 180K resistor in parallel with the 250k pot. equiv. R will be ~ 104K - close enough.
solder the 180k R from pin 1 to pin 3 of the pot.
