September 08, 2026, 01:56:29 pm
Hoffman Amps Forum image Author Topic: Ampeg B-15N - Documentation Link  (Read 9983 times)
« on: June 01, 2017, 05:05:35 am »
For those who can have interest on the B-15N Ampeg a link that I've find and that contains a lot of good info
https://www.talkbass.com/wiki/technical-amplifier/
Re: Ampeg B-15N - Documentation Link
« Reply #1 on: June 01, 2017, 09:40:57 am »
nice find!  I see you don't sleep well either :laugh:
« Reply #2 on: June 01, 2017, 11:20:04 am »
Ciao
May be it was not so early in the morning, here we are near Greenwich meridian  :wink:
add 7 hours to the time you see on the forum  :smiley:
« Last Edit: June 01, 2017, 11:24:22 am by kagliostro »
« Reply #3 on: June 01, 2017, 11:49:37 am »
cool! thanks for sharing that K!
building another all octal-socket amp is in the forecast. i'd probably go with SS recto.
Offline ManisMan
« Reply #4 on: June 12, 2017, 06:58:27 pm »
Question on fixed bias in that documentation. How does the biasing circuit work to provide a negative voltage to the grids?
Is it because you have both + and neg coming out of the secondary taps?
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #5 on: June 12, 2017, 07:07:41 pm »
Unless I'm looking at the wrong schematic, it's not fixed bias, it's cathode biased no?
~Phil
Phil Davis
tUber Nerd =|D
« Reply #7 on: June 12, 2017, 07:13:01 pm »
The early ones were cathode biased. Later ones were fixed bias. Keep scrolling down the page and you will see.
It's just a very simple half wave rectifier. Nothing special. Hundreds of amps use that same circuit.
    • Daviszone
« Reply #8 on: June 13, 2017, 12:00:34 pm »
Oh thanks mantisman and sluckey, that makes more sense :)  Yup that's a bias circuit I've seen over and over in my limited experience too.
~Phil
Phil Davis
tUber Nerd =|D
