September 17, 2026, 09:43:17 am
Hoffman Amps Forum image Author Topic: What to do with unused 5V PT secondary wires?  (Read 8250 times)
Offline Hellawatt
« on: June 21, 2017, 08:59:52 pm »
Hi. I am using an old Hammond organ PT from an ao-35 for a plexi 6V6 build. What is the best thing to do with the unused 5V secondary wires that went to the tube rectifier filament? Do I just isolate them or should they be connected to each other?
Re: What to do with unused 5V PT secondary wires?
« Reply #1 on: June 21, 2017, 09:11:53 pm »
NOT connected, isolated. Heat shrink the end on each one, then tuck 'em away in the corner of the chassis somewhere.
Offline Hellawatt
« Reply #2 on: June 21, 2017, 10:01:08 pm »
Got it. Thanks!
Just out of curiosity. What would happen if they were connected?
« Reply #3 on: June 21, 2017, 10:51:29 pm »
If lucky, you just blow a fuse every time you turn the power on. If not so lucky the insulation on the 5V wires would quickly melt followed by smoke from the power transformer.
I built a Plexi6V6 from a Hammond AO-43 and used a 5AR4 rectifier tube instead of silicon diodes.
     http://sluckeyamps.com/6v6plexi/6v6plexi.htm
Offline Leevi
    • Rikstone
« Reply #4 on: June 22, 2017, 02:47:32 am »
I normally connect the unused 5V to pilot lamp. The 6.3v lamp will shine brightly even with 5v and lasts longer.
/Leevi
« Reply #5 on: June 22, 2017, 09:44:09 am »
/Leevi
That's a great idea!
Offline Leevi
    • Rikstone
« Reply #6 on: June 22, 2017, 10:05:12 am »
If you plan to have relays in the amp the 5V AC can be used as a source for DC voltage.
After rectifier you'll get about 7.5V DC which is suitable for 5V relays.
/Leevi
« Reply #7 on: June 22, 2017, 01:16:53 pm »
5V, "zero" Ohms, "infinite" current!! Smoke!
In a real PT, the Ohms won't be zero. Figure a PT can dump short-term about 10X its rated current. So say 30 Amps will flow, from a nominal 5V source. 150 Watts of heat inside the transformer. Assume a 100 Watt transformer, which was designed to throw-off 10 Watts of heat on the way to a 100W happy output. 15 times the design heat in the windings.
It is a smaller version of what happens if you short-out the 120V/230V from a wall outlet. BOOM.
That's why we fuse wall-outlets and transformers.
Offline BrownIsound
« Reply #8 on: March 27, 2023, 01:28:24 pm »
Offline dude
« Reply #9 on: March 27, 2023, 02:25:01 pm »
That AO-35 PT used a 5Y3.  Not sure of the rating on that PT but I don't consider that PT a good choice for a fixed biased 6V6 Plexi (even with SS rectifier) you won't get the B+ needed for a real 6V6 Plexi.  If you still want to use the AO-35 PT, use diodes and Cathode Bias instead of the 6V6's fixed bias, your B+ will just about right for a Cathode Biased 6V6 Plexi.
And I built a 6V6 Cathode Biased Plexi, nice amp, especially for Blues.
