September 15, 2026, 01:18:04 am
Hoffman Amps Forum image Author Topic: SE build 6L6 redplating  (Read 6093 times)
Offline Tone Junkie
« on: June 26, 2017, 11:42:36 pm »
I have built 2 of these already all at 365 B+ 470 ohm cathode resister these were 5K transformer ,thought I would try 7K tap used different power transformer B+ is 450 tube is red plating just a bit. Im not good with cathode bias amps. Do I raise or lower the resister to get were I want. Cant remember.
Thanks Bill
Re: SE build 6L6 redplating
« Reply #1 on: June 27, 2017, 04:33:33 am »
one of three ways to get plate dissipation down. 1) increase the value of Rk and the simplest. 2) decrease just  the screen voltage: somewhat more complex. 3) reduce B+ overall: redesign or use B+ CT reduction methods - e.g., VVR, etc..
« Reply #2 on: June 27, 2017, 05:15:24 am »
put another 100 ohm 2W resistor in series with the 470 to test. problem is, as you reduce Ik, the B+ rises, so you end up using/needing even more resistance to overcome plate dissipation, and at some point you may get too close to or put the tube in cut-off region. if things come to that, then you'll need to reduce screen voltage and/or B+ overall.
you could also try a different brand/type of 6L6: some of the russian stuff is actually closer to 5881/6L6GB in ratings. NOS, svetlana/wingedC, MESA STR, and Grove tubes 6L6GC-GE are true variants of a 6L6GC.
out of curiosity, what is the DCV measurement from cathode to ground with the 470R cathode resistor installed? from screen (pin 4) to ground? from plate (pin 3) to ground?
« Last Edit: June 27, 2017, 08:30:12 am by DummyLoad »
« Reply #3 on: June 27, 2017, 08:26:22 am »
what is is the DCV measurement
+1
if you ignore the OT, consider the tube a "short" while conducting, 450VDC/470ohms puts you within a rounding error of 100mA for the tube.
« Reply #4 on: June 27, 2017, 06:59:40 pm »
The formula for calculating the optimum reflected load for a centre-biased output stage running in Class A is:
Zout = Va/(Pa/Va)
where:
Zout = the reflected load
Pa = the maximum recommended plate dissipation of the tube
Va = the (idle) plate voltage
With a 6L6GC and 450 plate volts, the 'ideal' plate load works out to 6,750R. 7k is good
Vg2 can happily be 5V or so under the 450V mark if you are running close to an optimum plate load. Use decent-sized Rg2 for screen protection (3W 470R would be fine)
Ia = 30W/450V = 66mA  for Class A operation. Ig2 will be around 5-6mA bringing the total tube current to ~70mA.
Size the cathode resistor accordingly. If we extrapolate a Vg2 = 450 from an average transfer characteristics chart for a 6L6GC*, we'll see that when running the screens at around 450V, with 66mA plate current, the bias voltage wants to be about -39V. Therefore, working with our total tube current of 70mA (including screen current), 39/0.07 = 557R (5W resistor). If you want to run 470R (giving Vg1 = ~-33V), you can drop the screens to 400V. (This can be confirmed with a quick glance at the bottom chart on page 9 of the linked datasheet, if you superimpose a DC load line with the bias point situated on 450V at 66mA plate current)
(*e.g. see bottom chart of page 6 of 6L6GC.pdf)
YMMV
Of course, if you have a 6L6GB or a 5881 or an earlier 6L6 type, you need to work off a different tube datasheet.
« Last Edit: June 27, 2017, 07:11:24 pm by tubeswell »
« Reply #5 on: June 27, 2017, 08:03:45 pm »
It was happy at 365V. Unhappy at 450V.
Get the B+ down. 500r-1K series with the OT feed gets the B+ down. Add a filter cap there.
Offline Tone Junkie
« Reply #6 on: June 27, 2017, 10:03:04 pm »
Thanks guys I will get some measurements and change the resistor out. I had a 200 and 360 ohm I could put together. I have 100 uf cap with that .
I will print this one out and put on my wall o,knowledge. I forget things because I have sleep issues, having it handy were I can look real quick has served me well.
Thank You Bill
Offline Tone Junkie
« Reply #7 on: June 29, 2017, 01:52:42 pm »
My voltage before the change with the 470 ohm R.was 425,pin 3 ,400 pin 4. 32v  across cathode cap and resister, after changing to 560 cathode resister, 460 pin 3 ,406 pin 4, and 35 across cathode cap and resistor. Tube is happy.
Thank you Bill
« Reply #8 on: June 29, 2017, 05:10:27 pm »
If I pushed the right buttons I have you Idling about 32W with those values
« Reply #9 on: June 29, 2017, 06:40:51 pm »
I get:
35V/560R = 62.5mA, minus ~5mA (Ig2) = 57.5mA
460-35 = 425V
425V x 57.5mA = 24.4W
« Last Edit: June 30, 2017, 03:02:59 am by tubeswell »
« Reply #10 on: June 29, 2017, 06:47:33 pm »
 :think1: you win :laugh:
I did 425/560 = 75.8mA, duh, what I get for multi taskin with my Gdaughter
