September 14, 2026, 10:19:09 pm
Hoffman Amps Forum image Author Topic: 66 Pro Reverb faceplate damage  (Read 4263 times)
Offline Voxbox
  • drrun-drrun-drrun diddle-diddle diddle-diddle
« on: June 30, 2017, 01:09:37 pm »
Help!
I've been working on a 1966 Pro Reverb and tried to remove some masking tape residue from the top of the front panel faceplate and managed (with some isopropanol cleaner) to take what appears a thin layer of slightly shiny clear lacquer off part of it. It now looks a bit tatty :(
Any suggestions for restoring an even sheen to the faceplate?
Cheers, VB
everything will be ok
in the end.
if it's not ok,
it's not the end.
Re: 66 Pro Reverb faceplate damage
« Reply #1 on: June 30, 2017, 02:31:58 pm »
Might try a waxing like spit shining boots.  I use WD40 on rubber to get a smooth finish, but I would be concerned with removing the silkscreen.  The ink used has cobalt as the drying agent and it is really tough, but anything with a solvent I would not use.
Some soap and water may even it back out, you may just have residue lingering.
Offline Voxbox
« Reply #2 on: June 30, 2017, 02:52:02 pm »
Thanks Ed, I did think about a wax finish. The Isopropanol went through the black of the faceplate a little so I'm really annoyed about that.
Any ideas for touching up?
I'll try the wax on the back first.
Cheers, VB
in the end.
if it's not ok,
it's not the end.
