September 15, 2026, 06:52:05 pm
Hoffman Amps Forum image Author Topic: 22798 PT  (Read 4295 times)
Offline davidwpack
    • My music on reverbnation
22798 PT
« on: July 10, 2017, 10:39:09 am »
Hey all. I've got a 22798 PT. It's got 3 6.3 heater wires, 2 green and one green/white. Can anyone tell me if the green/white goes to ground? Is this a CT? I assume it goes to ground but wanted to make sure. Thanks!
Re: 22798 PT
« Reply #1 on: July 10, 2017, 10:59:38 am »
It probably is a center tap but I'd want to know for sure. Measure voltage between the green/white wire and either of the green wires. If it's a center tap then the voltage will be half as much (3.15vac) as measured between green wires. If this is true then connect the green/white wire to chassis.
EDIT... Added pic
« Last Edit: July 10, 2017, 11:03:12 am by sluckey »
Offline davidwpack
Re: 22798 PT
« Reply #2 on: July 10, 2017, 12:09:05 pm »
Yep, sure is. Thanks!
