September 08, 2026, 12:17:39 pm
Hoffman Amps Forum image Author Topic: buzz in fender rumble 15  (Read 7197 times)
Offline drgonzonm
« on: July 17, 2017, 08:46:42 am »
I have a fender rumble 15, that occasionally starts to buzz (not sure if its 60 or 120 hz) when I plug an instrument cord into it.  I can sometimes get rid of the buzz by wiggling the cord.  But a few minutes later it starts again.  I use it in small venues, and buzz is a buzz killer (pun intended).
Re: buzz in fender rumble 15
« Reply #1 on: July 17, 2017, 10:41:28 am »
INput jack ground, guitar cable, guitar.  After that assuming it's a pcb, re-flow all the solder connections at input and PS
Offline drgonzonm
« Reply #2 on: July 22, 2017, 03:17:56 pm »
The rumble is low cost amp pcb based,  with comparable components.  The ground ring is loose, need to replace the mostly plastic input jack.
Thanks for the response shooter.
« Reply #3 on: July 22, 2017, 03:52:47 pm »
Hope that gets it, I'm not a big fan of plastic, especially when musicians interface with the stuff :laugh:
Offline drgonzonm
« Reply #4 on: July 22, 2017, 03:57:01 pm »
especially the plastic with chips and 16 digit numbers.  (Whats in your gig bag (wallet))   :icon_biggrin:
