September 17, 2026, 12:47:18 pm
Hoffman Amps Forum image Author Topic: 80's Marshall JCM 800 2205 Resistor Question  (Read 7326 times)
Offline boxcarcut
« on: July 18, 2017, 09:44:42 am »
I have an 80's Marshall JCM 800 2205 on the bench. There was a resistor across the DI Output Cliff Jack. It is burnt to a crisp. Not able to find it on any schematic. Could someone help me identify the value?
Offline SILVERGUN
Re: 80's Marshall JCM 800 2205 Resistor Question
« Reply #1 on: July 18, 2017, 09:58:25 am »
This?
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: July 18, 2017, 11:00:08 am »
How'd they do it?  It would take something well in excess of 7.1V to burn a 0.5watt 100 ohm resistor like that.  There is no source for that voltage in that amp as drawn.  You don't suppose somebody plugged the speaker output from another amp into the D.I. jack, do you?  I mean, it does say direct input, doesn't it?
« Reply #3 on: July 18, 2017, 11:17:51 am »
2Deaf, I think you got it...OUCH!
Offline SILVERGUN
« Reply #4 on: July 18, 2017, 11:25:44 am »
Let me guess....first hand experience?
Offline SILVERGUN
« Reply #5 on: July 18, 2017, 11:43:48 am »
Would having no speaker (or open voice coil) plugged into the speaker out jack have the same result?
 :dontknow:
Offline 2deaf
« Reply #6 on: July 18, 2017, 03:44:33 pm »
The worst case scenario would be with the D.I. pot. at max. so that it is only a 1K resistor in series with the 100 ohm resistor connected to the 4 ohm power source.  It takes 71mA to reach 0.5watts of power across that 100 ohm resistor.  That would be 78.1Vrms at the transformer end of the 1K resistor which is 110Vp.  It ain't going to happen.
Also, 0.5watt across the 100 ohm resistor means that there would be 5watts across the 1K resistor, so the 1K would burn up long before the 100 ohm.
« Last Edit: July 18, 2017, 03:51:02 pm by 2deaf »
