September 13, 2026, 01:04:43 am
Hoffman Amps Forum image Author Topic: Joel: re: RCA 6973 datasheet  (Read 4683 times)
« on: July 27, 2017, 05:53:02 am »
Hi Joel, we're taking Sluckey's thread off track; your topic needs it's own.
You've got a push-pull amp (you're using an 18W OT) this means you've got 2 power tubes. IF I'm thinking correctly, your figuring out your pDiss properly using your B+ & current numbers, but you're forgetting that your voltage being dropped across your K resistor is for 2 tubes. You need to take that dissipation and divide it by 2.
IIRC, you've got 350 volts at the plates, and you're measuring 21 volts across the 250 ohm K resistor. 21/250= .084. That's the current. .084 x 329 volts (plate-cathode) is 27.6 watts / 2 tubes = 13.8 diss per tube. So yes, it's a little over the 12 watts dissipation on the data sheet, but your tubes won't melt.
This is assuming that I'm understanding your original question, of course.  :icon_biggrin:
Offline Joel
Re: Joel: re: RCA 6973 datasheet
« Reply #1 on: July 28, 2017, 08:42:46 am »
Cheers John.
I'm not following some of your logic.  Can you run through the process from the top?  Starting with B+ 350V, and 8.4k output transformer.   How do you go about drawing the load lines, determining the bias point and hence an appropriate cathode resistor?  Then calculate the approximate output power?
The mouth of a happy man is filled with beer  - Egyptian Proverb
« Reply #2 on: July 28, 2017, 10:15:34 am »
I've never drawn a load line on a power tube, it's way too complicated for me. The only thing I pay attention to is max dissipation, and max plate voltage. Even those figures can be fudged up a little, due to the fact the data sheet are normally a little conservative. And those were drawn for uses other than guitar amps, where we like to push the envelope.
Offline drgonzonm
« Reply #3 on: July 28, 2017, 10:19:31 am »
To draw loadlines on tubes, download a copy of RDH4 from this website.
Practice drawing the loadlines on triodes first, then graduate to the pentodes.  chapter 12 and 13 respectively.
I have not seen the method to draw load lines for pentodes operating in UL (ultralinear) mode.
Good luck.
« Reply #4 on: July 28, 2017, 11:04:27 am »
just raise it to 45degrees n ur close enough :icon_biggrin:
