August 29, 2026, 03:03:28 pm
Hoffman Amps Forum image Author Topic: Reverb Transformer & Tank Impedance Matching  (Read 7547 times)
Offline mike123
« on: July 30, 2017, 04:48:56 pm »
Hi all, I'm building a Princeton Reverb (AA1164 circuit).
The 022921 reverb transformer from Hoffman Amplifiers has an input Z of 14500 ohms input & an output Z of 4 ohms.
The Mojo 4AB3C1B tank from Hoffman has an input Z of 8 ohms.
Googling around it appears that the typical Fender 022921 reverb transformer has an input Z of about 25K ohms & an output Z of 8 ohms.
What will be the effect of this Z mismatch be on my reverb?
Cheers
Mike
Offline 2deaf
  • Now too deaf for 100 watts
Re: Reverb Transformer & Tank Impedance Matching
« Reply #1 on: July 30, 2017, 05:54:14 pm »
There is no impedance mismatch.  25K : 8  is almost the same ratio as 14.5K : 4  and it turns out that this is how output transformers work.
« Reply #2 on: July 31, 2017, 12:36:43 pm »
I think Mike mean which will be the effect of mismacth using the 14500/4 ohm transformer with a load of 8 ohm
14500 x 2 = 29000 ohm
so 29000 ohm primary instead of 25000 primary
I think he will reach only a bit lower strongness of the signal, but probably no other negative effects
« Last Edit: July 31, 2017, 12:40:19 pm by kagliostro »
Offline 2deaf
« Reply #3 on: July 31, 2017, 05:08:31 pm »
Probably it.
Offline mike123
« Reply #4 on: August 06, 2017, 10:43:41 pm »
Thanks all for the input. The amp build is now complete & the reverb sounds lush!
« Reply #5 on: August 07, 2017, 11:27:26 am »
Nice :smiley:
but ...... with wich configuration for the reverb transformer + tank ?
Offline mike123
« Reply #6 on: August 09, 2017, 06:13:47 pm »
With the "mismatched" tank.
