September 08, 2026, 09:06:24 pm
Hoffman Amps Forum image Author Topic: Cool PCB CNC  (Read 16838 times)
Cool PCB CNC
« on: August 10, 2017, 02:12:06 pm »
should make prototyping a lot easier - not fond of all those developer chemicals and lamps.
https://www.eeweb.com/project/arduino-pcb-ink-plotter-cnc-machine
 :thumbsup:
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Cool PCB CNC
« Reply #1 on: August 10, 2017, 02:19:03 pm »
I have also seen some CNC's used to cut through solid copper boards so that they leave behind the traces as needed, and if you do this on top and bottom correctly, you can do some pretty wicked stuff too.
Here's a link to an example:
https://www.youtube.com/watch?v=I9SwoUCcFVU
~Phil
Phil Davis
tUber Nerd =|D
Re: Cool PCB CNC
« Reply #2 on: August 13, 2017, 12:27:00 pm »
I have done the above method, but removing all that copper is a pain in the ass and takes forever
The method I ended up using just removes copper around the traces and leaves all the rest in place
Like this
    • Daviszone
Re: Cool PCB CNC
« Reply #3 on: August 14, 2017, 12:32:18 pm »
Oh nice, and I guess as a side effect you get a lot more current handling :)
I'm going to have to give that style a try when I get mine!
~Phil
Phil Davis
tUber Nerd =|D
Re: Cool PCB CNC
« Reply #4 on: August 14, 2017, 12:35:27 pm »
I am isolating the traces and they are still the same size
The material not being removed can be thought of as a ground plane
    • Daviszone
Re: Cool PCB CNC
« Reply #5 on: August 14, 2017, 06:24:11 pm »
Oh ok, they're just a lot closer together.  I'd guess for the LED's that's not a big deal, for audio purposes, though, it may not be as great an idea... but smart routing may be  the solution to that.
Phil Davis
tUber Nerd =|D
