August 29, 2026, 03:02:52 pm
Hoffman Amps Forum image Author Topic: help me try and identify a build  (Read 6198 times)
Offline Emresound
« on: August 23, 2017, 08:12:55 am »
Bit of a random one. Bought a cab and I inherited a chassis.
I'm trying to work out what it is and if I can restore or bring it back to life.
I've managed to take a few photos and upload them. It might help with the transformers. Looks like it has a choke. Uses 2 x 6l6s and a 5y3 rectifier.
Note: I tried with photobucket and failed. Tried now with google photos...
https://goo.gl/photos/F7hSZZscVdn7afUN7
https://goo.gl/photos/N9dkhFhbdSGa3Sjy5
https://goo.gl/photos/49ZruSWhUAY6CtuM7
Bit of a random shot in the dark but I sure could help to find a direction with this build.
Thanks!
« Last Edit: August 23, 2017, 08:20:00 am by Emresound »
Re: help me try and identify a build
« Reply #1 on: August 23, 2017, 08:19:20 am »
Hmmm...
Offline Emresound
« Reply #2 on: August 23, 2017, 08:20:33 am »
Hmmm...
Sorry failed at photobucket  :l2:
Tried google photo now... :(
« Reply #3 on: August 23, 2017, 08:31:34 am »
What does the front panel look like? The amp looks home-made to me. Could be anything. You'll probably need to draw a schematic.
« Reply #4 on: August 23, 2017, 08:31:58 am »
Not enough info.  Cant see the tone stack.  If the tone stack is a TMB and you check the caps, usually this will narrow it a lot.  Fender or Marshall, but having 6L6 I bet Fender type.  The OT is a Heybour 4k multi-tap 4-8-16, basically a Bassman Trans.  So anything fender in the 40 to 50 watt range.
Since the AB763 is the most popular build, that is my guess unless it has no reverb, then a Bassman.
« Reply #5 on: August 23, 2017, 08:46:38 am »
Does it work?
Any sound?
Voltages?
If you can get it to play but don't like the sound then it won't matter what it is....except you won't know what not to build.
If you can get it to play and you love the sound then it won't matter what it is.
First thing, make sure it is SAFE.
Second, see how it sounds.
Third, season to taste.
« Reply #6 on: August 23, 2017, 02:56:45 pm »
Power transformer is probably Weber W025130.
You may find most of it is Weber-stuff.
