August 29, 2026, 04:56:13 pm
Hoffman Amps Forum image Author Topic: Stout TMB with 6v6 Question  (Read 11375 times)
Offline Bwmitc9285
« on: August 23, 2017, 01:53:57 pm »
This is my first post on the forum (though I've been visiting this site for years) so I apologize if this has been asked/answered elsewhere. I am looking to build a Stout TMB but would rather it have 6v6's instead of the standard EL84. If anyone has a schematic with 6v6 values or specific component changes I would greatly appreciate it.
Re: Stout TMB with 6v6 Question
« Reply #1 on: August 23, 2017, 03:13:02 pm »
In general, from EL84 to 6V6 only needs a bigger cathode resistor under the 6V6es. Steal a value from any 6V6 plan of similar voltage.
« Reply #2 on: August 23, 2017, 09:19:15 pm »
another option is to take 6v6 plexi phase inverter, output stage, & power supply plan and graft stout TMB pre-amp to that. 6V6 plexi is fixed bias, still will work fine.
stout TMB schema:
http://el34world.com/Hoffman/files/Hoffman_Stout.pdf
6v6 plexi:
http://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V2.pdf
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #3 on: August 23, 2017, 11:47:24 pm »
I am just finishing up that exact modification and it is really nice.
I struggled with it for a while, but it is getting closer to where I want it.
I am actually going to work on it tonight and try a different rectifier as one experiment.
I built the amp as a back up but it is becoming a player.
I can assist with any component values if you need.  BTW, my bass response is huge, I am going to try and tighten it up a bit as well.
Offline Bwmitc9285
« Reply #4 on: August 24, 2017, 07:05:31 am »
Thanks for the suggestions everyone. After comparing a few different schematics I think I am going to change the cathode resistor to a 250r and the PI tail resistor to a 22k. Other than changing out the sockets I think these are the only two things that need changing?
Purpletele are there any other changes you made?
Offline purpletele
« Reply #5 on: August 24, 2017, 08:07:38 am »
I changed everything I could.
However, I am not as clever as Doug and the boys.
I recently changed everything bac to stock.
I think I have a 12AT7 in v2 for more headroom.9
« Reply #6 on: August 24, 2017, 05:50:45 pm »
tweedy stout...
see attached.
edit: updated schematic notes, etc.
edit: corrected C9 / R11 node.
« Last Edit: August 28, 2017, 06:53:23 pm by DummyLoad »
« Reply #7 on: August 25, 2017, 05:11:03 am »
Is R11 for the negative feedback drawn correctly?
« Reply #8 on: August 25, 2017, 06:49:07 am »
R11 is correct but C9 is wrong. C9 should connect to the junction of R11 and R12, not ground.
« Reply #9 on: August 25, 2017, 06:56:15 am »
That's what I was hinting at.  :icon_biggrin:  :thumbsup:
« Reply #10 on: August 25, 2017, 10:02:31 am »
> C9 is wrong.
Either/or.
C9 is drawn "right" for basic operation.
C9 the other way is Fender-style.
Offline Bwmitc9285
« Reply #11 on: August 25, 2017, 11:30:04 am »
Thanks for the schematic Pete. That definitely helped clarify some values. It looks like these are the components that need updating on the standard EL84 TMB board.
EL84 Stout6V6 Stout
R18: 47K33K
R13: 100K91k
R21: 470K100K
R22: 470K100K
R25: 130R270R
C10: 47UF33UF
R23: 8.2K1k5
R24: 8.2K1k5
R26: 1K470R
R27: 1K470R
« Reply #12 on: August 25, 2017, 07:56:23 pm »
This is the critical change.
EL84 Stout   6V6 Stout
R25: 130R   270R
All the others are minor differences. EL84 and 6V6 are more alike than different, and same values in the preamp and driver will work for either. Differences above are more a matter of taste or fine-tweak than essential.
The killer difference is the 6V6 cathode resistor *must* be almost double what works for EL84. If you use '84 value under 6V6, they will melt.
« Reply #13 on: August 26, 2017, 12:31:26 am »
corrected schema and attached revisions to reply #6.
apologies for any confusion.
as stated - cathode resistor is the major change. i tuned the LTPI for a bit more drive and balance, otherwise use doug's plan.
Offline Bwmitc9285
« Reply #14 on: August 26, 2017, 10:07:46 am »
No confusion at all. I appreciate the suggestions. I just placed an order for parts using the updated values and I'll post some pictures once I get everything up and running. Thanks for the help everyone!
Offline purpletele
« Reply #15 on: August 26, 2017, 10:11:01 am »
I have Sherman the former EL 84 Hoffman Stout up and running as a really smooth 6 v 6 amp.  I am planning on a nice video soon.
It's smoother/cleaner than my 18 watt Plexi.  I had a 5Y3 GT Rectifier in it and I switched to a 5AR4.  It has quite a bit of sag, much different that the SS rectifier on my Plexi and Dr. Z Remedy.
I installed an EQ by pass which is quite useful for natural light OD.
This amp platform could benefit from an FX Loop.  I haven't searched but maybe there is a schematic for the loop on something similar.
I have that on my list to develop a plan but I have two other projects in front of that.  It might be something that interests a lot of folks.
Offline Bwmitc9285
« Reply #16 on: August 28, 2017, 03:37:00 pm »
I have updated the Hoffman provided Stout TMB schematic to match the suggestions listed above in case anyone else is looking to build one of these.
« Last Edit: August 28, 2017, 04:22:06 pm by Bwmitc9285 »
Offline purpletele
« Reply #17 on: August 28, 2017, 04:08:07 pm »
I found that my amp had a really strong bass response with a .022 cap and the 6 v 6 tubes.  I changed it to .047 the other night and that seemed to help it but I haven't fully tested it.
Also, the amp felt like it had a lot of sag so I changed the 5y3 to a 5ar4 and that had a positive affect.
My amp has gone through a metamorphous state and has come out as a really sweet sounding and powerful clean amp platform and it responds well with pedals.
I keep threatening to make a video, it will be soon.
« Reply #18 on: August 28, 2017, 06:42:07 pm »
SSR & larger plate and screen filter will tighten it up significantly... some like a little sag though so 5AR4 is a good compromise.
Offline purpletele
« Reply #19 on: August 28, 2017, 06:49:56 pm »
Pete, thank you,
I think it is really nice right now, but I would like to try a larger filter.  Can you point me to the correct Plate and Screen filter?  I am reviewing the schematic now.
I have two Plexi amps with SSR which I really like but this amp is a great rhythm guitar amp.
Thanks,
BV
« Last Edit: August 28, 2017, 07:04:03 pm by purpletele »
Offline purpletele
« Reply #20 on: August 31, 2017, 12:37:12 am »
Pete,
I reviewed your schematic and your notes make sense, thank you.  I really like the creative use of the two Cap Cans.
I think I am going to leave Sherman as is for a while.  I like the SAG for now and it sure has a nice slightly Marshally tone.
Offline Bwmitc9285
« Reply #21 on: September 13, 2017, 01:57:32 pm »
Just got the amp finished up. The only other change I made is I used a deluxe reverb output transformer since the amp now has 6v6s. I don't have tubes yet but I'm going to test it out tonight without them and see what the voltages are. The cab was my first attempt at woodworking/ tolexing and it's not perfect but it will do. Thanks again for everyone's help so far!
Offline purpletele
« Reply #22 on: September 13, 2017, 03:35:18 pm »
Very nice work!
Offline Bwmitc9285
« Reply #23 on: September 17, 2017, 05:53:00 pm »
I got the tubes in last night and it fired right up and sounded great. The voltages look a little low to me though. These values are without a current limiter. I used the values listed in the most recent schematic above. Do these look abnormal to anyone?
A: 315
B: 308
C: 274
D: 265
V3 (JJ6v6S)
Plate: 305
V4 (JJ6v6S
Plate: 305
Voltage drop across cathode resistor: 18v
« Reply #24 on: September 17, 2017, 06:25:12 pm »
my math shows about 9.4w a tube, your values do seem low compared to the schematic
but;
