September 08, 2026, 12:18:20 pm
Hoffman Amps Forum image Author Topic: Crate GX-65 Loud noise  (Read 7600 times)
Offline TerryD
« on: August 28, 2017, 10:03:48 am »
I have my friend's amp here.  I'm not too familiar with solid state.  He complained of a loud HUM.  I could get it to do it once.  It is loud hum going into a buzz.  Any idea what that could be.  having a hard time getting it to do it again.  Grounding problem???  How do you trouble shoot this??  Thanks,Terry
Re: Crate GX-65 Loud noise
« Reply #1 on: August 28, 2017, 12:44:30 pm »
schematic, name, brand?
sand isn't much different than tube Tshooting, voltage checks, physical inspection, isolating what works n what don't, but for help schematic is almost a must, pcb types, good pics of both sides maybe
« Reply #2 on: August 28, 2017, 04:14:54 pm »
name, brand?
:BangHead:
sorry just read body NOT title :BangHead:
Doug has a GX120 schematic, from that I would monitor both the +/- 40 and +/- 15 for starters
work 1 channel at a time to see if it hummz,
some good "slapping around" with chop-stick might spook the intermittent, typically loose solder joint
I don't know age or service, but if it's 10ish years, ecaps.
you can probably stick a tone signal in and let it run, while beating on it, the gremlin Will eventually peek out.
« Reply #3 on: August 28, 2017, 07:22:01 pm »
Power supply hum/buzz usually won't stop.
Come-and-go hum/buzz suggests jacks. (Also cord plugs.....)
Offline TerryD
« Reply #4 on: August 28, 2017, 07:54:06 pm »
Thanks all.  I'll get to it.  Terry
