September 08, 2026, 08:33:47 pm
Hoffman Amps Forum image Author Topic: Hoffman relay power supply board for D.C. Elevated heaters?  (Read 5490 times)
Offline Gainzilla
« on: August 28, 2017, 03:43:38 pm »
hi all,
Wondering if I can use the Hoffman relay supply board to power D.C. Elevated heaters. The schems I've seen show a bridge rectifier (20A) and an eCap powering the filaments. Would I just omit the voltage regulator, or is there a voltage regulator I should look for with maybe closer to 50v?
Schematic below (hand-drawn looking one), then the Hoffman Board & Schematic:
I know it's only Rock and Roll, but I like it. \m/
Re: Hoffman relay power supply board for D.C. Elevated heaters?
« Reply #1 on: August 28, 2017, 04:26:41 pm »
not sure on using Dougs board as a starting point, I've done DC filaments twice, didn't get what I paid for :laugh:
Here's a snippit from a VOX (AC4?) that uses DC for the pre and AC for the power tubes
« Reply #2 on: August 28, 2017, 08:07:51 pm »
6.3VAC will never make big *clean* 6.3V DC due to rectifier drops and ripple.
Neither hand-drawn plan is "elevated".
If you already *have* DC, you don't need the Hoffman board at all. Use your DC to power the relay. You can find 6V relays, or add a resistor to drop to 5V for 5V relays.
Offline Gainzilla
« Reply #3 on: August 30, 2017, 01:45:32 am »
Thanks, guys!
