August 25, 2026, 04:32:49 am
Hoffman Amps Forum image Author Topic: AB763 backwards doghouse?  (Read 4504 times)
Offline evancorylevine
« on: September 02, 2017, 04:44:35 pm »
Hey loves.
I fear that I may have installed the components in the doghouse upside down. I can't just turn it around because the mounting screws and the through-holes to the inside are asymetrical. Do I need to turn this all around, or is it okay if some of my wires to the doghouse run a little longer?
Re: AB763 backwards doghouse?
« Reply #1 on: September 02, 2017, 05:49:58 pm »
If you're happy, that's what counts. The important issue is connecting the wires IAW the schematic. Couple inches extra length means nothing.
I would personally redo it but I'm anal about that stuff. I once threw a chassis in the trash because of a backward layout error.
« Reply #2 on: September 02, 2017, 07:23:35 pm »
If you are going to build a million of them, saving the penny on wire will delay you going broke.
For a one-off, I would not fret.
Offline bnwitt
  • Crankin' out the tone.
« Reply #3 on: September 03, 2017, 08:13:03 am »
attached is how the Fender higher wattage amp cap boards are typically wired
« Last Edit: September 03, 2017, 08:29:01 am by bnwitt »
