September 13, 2026, 08:12:45 am
Hoffman Amps Forum image Author Topic: Looking to build a high voltage tube tester  (Read 7872 times)
« on: September 05, 2017, 07:02:45 pm »
Hey guys, did a forum search and I cannot find a discuaaion on making a tube tester.  I have a hickock 6000A, which is a good tester, but I recall someone mentioning a few years ago about either making or a design for a tester that would test tubes under operating voltages.
I would like to add one, but of course I do not need to test a large variety.  I would like to test 9 pin and octals.  For the power tubes, testing at 500 vDc wuld be nice, but most commercial testers are only 400 VDC.  I really do not know why so input is appreciated.Up to 300 for small tubes would be nice.  Of course, I do prefer adjustable.
I wish to match power tubes and check balance in dual bottles.  If anyone has a schematic/layout and method, if you have the desire to share it would be appreciated.
Re: Looking to build a high voltage tube tester
« Reply #1 on: September 05, 2017, 07:42:35 pm »
Build a Champ, two sockets at each location. Bring key points out to meter-holes.
Run known-good tubes through it. All good 12AX7 will be around 150V-200V at plate. 6SL7 will run a bit lower. All good 12AU7 or 6SN7 somewhat lower. If a ??? tube doesn't read like others, doubt it.
EL84 wants a smaller Rk than 6V6 6L6 for maximum output. But EL84 will work with 6V6 values, just make a note of what an average good EL84 reads.
Also feed guitar and speaker. 12AU7 needs more strum-power than 12AX7 but it will play OK. A tube may come to nominal DC values but rattle or hiss or buzz or ring like a bell. Such non-test problems may be more important than finding exactly 1,600uMho @ 1.5mA.
« Reply #2 on: September 05, 2017, 09:07:05 pm »
Maybe this will float your boat:  http://triodeel.com/tester.htm
Though it sure makes PRR's suggestion seem attractive, which also let's you listen to a tube to check for microphonics, e.g.
« Reply #3 on: September 05, 2017, 09:33:41 pm »
thank to both of you.  Good stuff.
« Reply #4 on: September 05, 2017, 09:37:02 pm »
this one gets good reviews...
http://www.dos4ever.com/uTracer3/uTracer3_pag0.html
« Reply #5 on: September 06, 2017, 05:41:25 am »
Thanks DL. Just a quick review of this has thrown me a curve. Some of the builds housing the board are first rate, but they also show basic approaches.
Again, good stuff.
« Reply #6 on: September 06, 2017, 09:34:17 am »
i would add automation: select from a menu and relays to configure the appropriate connections to the appropriate socket. IF i were to build one. and...IF i wanted a modern tester, i'd just probably just buy an amplitrex.
http://amplitrex.com/
they're asking price is not unreasonable for what it does and is in-line for a decent piece of test gear, just don't need that level of testing. no one really does unless you're a distributor or an obsessed hi-fi nut.
i'm with PRR, just need to build the champ "test" fixture...  :icon_biggrin:
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #7 on: September 06, 2017, 04:14:06 pm »
What is that 'not unreasonable' price?  I don't see one on that site?
~Phil
Phil Davis
tUber Nerd =|D
« Reply #8 on: September 06, 2017, 08:51:14 pm »
~Phil
2.9k
Offline MaBerY
« Reply #9 on: September 08, 2017, 02:52:18 am »
I have build this thing and a friend of mine did too. Works like a charm.
It has a bit of a learning curve adjusting measurement parameters in the accompanied windows software, but it is well documented on Ronald Dekker's site
