September 08, 2026, 01:11:22 pm
Hoffman Amps Forum image Author Topic: Looking for a proven ENGL Fireball  (Read 9805 times)
Offline Johntb
« on: September 10, 2017, 01:23:34 pm »
I used one with obvious flaws that I worked through and got it to work somewhat on the overdrive channel. C!ean wa another story though. I spent over two months on it then just got frustrated and made something else.
Is there a proven schematic out there?
Proud to be self taught but, my teacher is an idiot.
Offline eldredjames
Re: Looking for a proven ENGL Fireball
« Reply #1 on: September 10, 2017, 09:15:35 pm »
Have you checked the one on Tube Amp Schematics Library
http://el34world.com/charts/Schematics/files/engl/Engl_Schematics.htm?
 There's one there.
Offline Johntb
« Reply #2 on: September 10, 2017, 10:41:37 pm »
Yup. That's what I started with. The first most obvious problem is V2 pin 7 goes straight to ground. Like that it won't work. I changed it to a 470k (and several other values and different caps in parallel). I ended up getting it to work in overdrive. Problem was everytime i got a good overdrive tone the clean was junk. I also had made several other changes i don't remember now. There are problems with the "depth" as well. The way it is it won't do anything and I worked past that too. Another issue was the "FX Loop" can't really remember that one right now.
I found this and was considering it but not sure. About 15 or so posts down Brutar posted on graph paper.
 http://guitar-gear.ru/forum/topic/402-%D1%81%D0%BE%D0%B1%D0%B8%D1%80%D0%B0%D0%B5%D0%BC-engl-e625-fireball/
I may just end up trying it.
But thanks for the reply.
Offline Johntb
Re: Looking for a proven ENGL Fireball (Found)
« Reply #3 on: May 27, 2018, 05:00:35 pm »
Well at least I like the sound I got. The preamp was a little further in the thread above (I tried to attach it). I used the amp section of the Superlite with 2 EL84's and an OT from and old Hammond organ.
I used the FX loop and it works fine but there is a very small amount of volume loss when fully "wet".
Still getting rid of some hum but it sounds great so far.
« Last Edit: May 27, 2018, 05:14:41 pm by Johntb »
Offline Johntb
Re: Looking for a proven ENGL Fireball better clip
« Reply #4 on: May 27, 2018, 11:03:28 pm »
Added video.
Beginning hum can be heard. This is as quiet as I have been able to get it.
Some clipping distortion on clean from phone and using bridge pickup. Used neck only later to show depth and bright switches.
Not sure if I added link correctly.
« Last Edit: June 09, 2018, 01:34:05 pm by Johntb »
