September 16, 2026, 12:03:20 am
Hoffman Amps Forum image Author Topic: Eyelet Press  (Read 7316 times)
Offline cusebassman
Eyelet Press
« on: September 11, 2017, 01:25:47 pm »
Hey all - search turned up nothing, so I'm curious. I'd like to make my own eyelet fiber boards, by drilling the holes and then manually installing the eyelets. What type of eyelet/grommet press is recommended for boards 3" high and smaller? How big should the eyelets themselves be? There appear to be many options on amazon, but none of the presses indicate how deep the press can fit over the work being pressed.
Re: Eyelet Press
« Reply #1 on: September 11, 2017, 01:57:47 pm »
Re: Eyelet Press
« Reply #2 on: September 11, 2017, 02:41:32 pm »
I just use my benchtop drill press and Hoffman's staking tool. I also use my bench drill press for making holes in various materials. You should be able to buy a decent bench drill press for under $150.
Offline cusebassman
Re: Eyelet Press
« Reply #3 on: September 11, 2017, 03:16:29 pm »
Thanks for the advice. I actually have a drill press, so it wouldn't be an issue.
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Eyelet Press
« Reply #4 on: September 11, 2017, 03:43:06 pm »
Hey I'm curious, your docs show how to use your tools for turrets, do they work fine for eyelets as well?  I've ended up just using a flat end of a bolt for the top and a metalworking stake that has a 60' angle on the tip that I press down into it.  You mentioned it for eyelets but all of the demos seem to be setup for turrets with the hole in the one side for turrets as well.  Do you  need some kind of special receptacle end for the curved side of the eyelet?
~Phil
Phil Davis
tUber Nerd =|D
Offline bnwitt
  • Crankin' out the tone.
Re: Eyelet Press
« Reply #5 on: September 11, 2017, 03:53:39 pm »
The best accessory I've ever purchased for improving my board building process is my Drill Press table.  I can get consistent turret or eyelet stamping and straight rows of turret or eyelet holes with the fence.
Re: Eyelet Press
« Reply #6 on: September 11, 2017, 04:41:49 pm »
Here's my simple turret press using Hoffman's turret staking tool...
Re: Eyelet Press
« Reply #7 on: September 11, 2017, 04:55:04 pm »
~Phil
You flip top tool around and just use the flat side to push down on the rim of the eyelet. The bottom pointy tool works the same on the bottom of an eyelet or on the bottom of a turret lug
    • Daviszone
Re: Eyelet Press
« Reply #8 on: September 11, 2017, 04:56:13 pm »
cool yeah I thought so, I'm thinking I may buy yours, mine's showing signs of wear already and I don't know how well it will last, but I'm on the fence right now.  Thanks!
~Phil
Phil Davis
tUber Nerd =|D
Re: Eyelet Press
« Reply #9 on: September 11, 2017, 04:57:32 pm »
On my press i Custom sculpted both tool pieces much nicer than the basic tool I sell.
I used a small lathe to cut my custom tools.
My bottom tool has a spring attached that pushes the board up and seats the terminal just before its swages the backside
Somewhere here on the Forum I posted a picture of my press recently for Steve
« Last Edit: September 11, 2017, 05:01:25 pm by EL34 »
    • Daviszone
Re: Eyelet Press
« Reply #10 on: September 11, 2017, 05:34:07 pm »
Yeah I remember it, I saw it, I read most posts but don't always comment :)  I definitely like that spring, it's a good idea.  So far with eyelets I don't get any 'sticking' but I am sure it would stick with the turrets.
~Phil
Phil Davis
tUber Nerd =|D
Re: Eyelet Press
« Reply #11 on: September 11, 2017, 06:04:50 pm »
Nothing sticks, the spring pushes the board material up and seats the terminal flat against the surface
The spring I use is quite hard to compress with your fingers and it pushed up hard on the board material
You do not have to physically lift the material with your arm
Doing lots of terminals sucks without the spring, and I do lots of terminals
Also, your hand is grasping the edges of the material and it tends to cut into your hand
It is possible to seat a turret lug incorrectly if it's not fully down flush with the surface of the material
The spring solves all the issues nicely
« Last Edit: September 11, 2017, 06:16:25 pm by EL34 »
    • Daviszone
Re: Eyelet Press
« Reply #12 on: September 11, 2017, 06:11:10 pm »
Oh gotcha, that makes sense, thanks!
~Phil
Phil Davis
tUber Nerd =|D
