September 14, 2026, 08:50:57 am
Hoffman Amps Forum image Author Topic: Improving a Crap PCB board input with a Switchcraft input jack question?  (Read 7992 times)
Offline TerryD
I want to put a "real" input jack on my friends Hot Rod Deluxe.  I don't know if I'm using the right terminology but how can I tell where to put the wire for the ground switch.  I can tell the ground from the positive by putting a jack in and using a multi-meter.  But the ground switch that turns it off when there is no plug in the jack, how do you tell that point?
Thanks, Terry
Re: Improving a Crap PCB board input with a Switchcraft input jack question?
« Reply #1 on: October 28, 2017, 11:21:40 am »
1) look at the datasheet.
2) insert a 1/4" jack. with an ohmmeter find the tip lead & sleeve lead(s). by default the remaining is the switch lead.
« Reply #2 on: October 28, 2017, 12:05:28 pm »
the wire typically grounds the tip when nothings plugged in, so it goes from tip to ground
« Last Edit: October 28, 2017, 12:09:18 pm by shooter »
Offline TerryD
« Reply #3 on: October 28, 2017, 12:46:05 pm »
Thank you.
Offline bnwitt
  • Crankin' out the tone.
« Reply #4 on: October 28, 2017, 04:30:29 pm »
This is a common modification on both Hot Rod and Blues versions of Fender amps.  Torres Engineering even sells a kit for it:
http://torresengineering.stores.yahoo.net/newjacrepkit.html
I've done this on several of these amps as well.  Check out the two attached files
« Last Edit: October 28, 2017, 04:38:43 pm by bnwitt »
Offline 92Volts
« Reply #5 on: October 29, 2017, 01:08:03 pm »
On a Fender amp where I have seen this done, the PCB-mount jack had a separate pin for the connection that's shorted with nothing plugged in. This had its own hookup point on the PCB, which could be identified by ultimately being on the same PCB trace as the ground...
But you can also hook this to the ground of the jack itself and use only wire to the ground on the board.
EDIT: slucky pointed out this might not be a good assumption, and this shortcut wouldn't work with hi/low level jacks.
You can usually examine the original PCB mount jack to determine the layout of the different connections on the PCB and use them accordingly with the new jack.
« Last Edit: October 29, 2017, 01:34:15 pm by 92Volts »
« Reply #6 on: October 29, 2017, 01:23:25 pm »
That won't work for every input jack on amps that have "Hi" and "Lo" input jacks such as Hotrod Deluxe, or the reissue blackface amps. The Hi jack does connect the switch terminal to ground but the Lo jack connects the switch terminal to the Hi jack tip terminal.
Offline 92Volts
« Reply #7 on: October 29, 2017, 01:32:14 pm »
Good catch. And of course, Fender amps are often configured like this.
Offline TerryD
« Reply #8 on: October 29, 2017, 02:42:45 pm »
So, I'm a little confused now.  Can I change just one input to a swtchcraft jack on the Hot Rod Deluxe?
A guy on YouTube does one and removes the grounding wire because with the switchcraft its now grounded at the chassis.
« Reply #9 on: October 29, 2017, 02:54:33 pm »
this may help, start at page 7.  This is a great pdf :laugh:  also showed me 1 jack is ALWAYS best :icon_biggrin:
Offline bnwitt
« Reply #10 on: October 29, 2017, 03:46:44 pm »
I would change them both
« Reply #11 on: October 29, 2017, 08:42:55 pm »
Here's a complete tutorial:  http://hotroddiy.com/howtoarticles.php
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #12 on: October 30, 2017, 01:32:33 am »
I've done this on mine (blues deluxe) because the plastic ones came out.  It worked great for me.   I did a youtube video on it a while ago, can't be sure where it is, I'd have to hunt if interested.
~Phil
Phil Davis
tUber Nerd =|D
Offline TerryD
« Reply #13 on: October 30, 2017, 08:55:55 am »
Phil, I'm very very interested.  This is the first time, on this board, that I'm a little more than confused.
Thanks for the effort.
Terry
Offline bnwitt
« Reply #14 on: October 30, 2017, 06:51:13 pm »
I know the 1-2 input jack is foreign when one is not used to it but once you've done a few you'll be amazed how simple it is
« Last Edit: October 30, 2017, 06:54:45 pm by bnwitt »
    • Daviszone
« Reply #15 on: October 31, 2017, 12:37:31 pm »
Terry
Found it, not sure if my video will be helpful though, let me know if it is or isn't :P
~Phil
Phil Davis
tUber Nerd =|D
