September 14, 2026, 12:22:42 am
Hoffman Amps Forum image Author Topic: Troubleshooting first build.  (Read 7534 times)
Offline Tapsnap
« on: November 06, 2017, 07:13:37 pm »
This is my first amp build and I am experiencing some problems. Here is the schematic and some pictures.
 Sometimes the amp works at full volume though with a lot of buzz, then suddenly it cuts to half the volume for no apparent reason. I have checked all the voltages and all seem good except for the one at R9. which is 110V not 85V. I have checked all resistors and changed the pots, re-routed the grounds, checked all the connections to the tube holders, pots, jack sockets, but I am still getting the same problem.
One thing I don't fully understand is grounding. A good explanation as to how to ground an amp and where to connect to, but more important, what not to do and why would be really helpful.
Re: Troubleshooting first build.
« Reply #1 on: November 06, 2017, 08:45:14 pm »
Nice floor!!!,
the schematic is good looking, your build looks like my 1st few :laugh:
look at the board in the is link;
http://el34world.com/Forum/index.php?topic=22495.0
find the achieve section here and check out the how to troubleshoot links
guessing the yellow wires are filament?
If so get them as far away from V1 and associated components n wires as you can.
search grounding in this forum section, the 1st take-away, keep preamp ground from power amp ground
hang in there, you'll be playing soon
the cutout problem probably an iffy solder joint somewhere
Offline Tapsnap
« Reply #2 on: November 07, 2017, 07:44:13 am »
"the 1st take-away, keep preamp ground from power amp ground"  OK see, this is what I don't understand. Don't all the grounds eventually go to the same place? I have them all going to the green grounding wire coming from the AC Power. Is there some ground I don't know about that I should be connecting to instead?
« Reply #3 on: November 07, 2017, 08:47:22 am »
here's some explanation n examples;
http://el34world.com/Forum/index.php?topic=9267.msg84015#msg84015
a ground point n a ground plane are somewhat different. a chassis is a ground plane, a bolt n nut are a ground point on that plane.  I'm NOT a theory guy.  everything pre, ground at input jack, everything PA ground at PT bolt.
get the amp reliable, no signal loss plays well, then clean up wiring and grounds, then play!
here's my studio floor, maybe we can collaborate on a Pollock tribute :icon_biggrin:
« Reply #4 on: November 07, 2017, 08:57:42 am »
If you could figure out how to capture that on canvas lot's of folks would pay good money for it. Especially if you make up some story about how you struggled to reach that point in life. Heck, even prints of that photo would sell.
« Reply #5 on: November 07, 2017, 10:35:11 am »
:l2: that would be a novel stranger than fiction!
My nephew already claimed the floor if I sell the house :icon_biggrin:
It's funny, I have a pretty good group of millennial artist friends, I offer them 1/2 to sell my works, their to lazy to even try!!! :think1:
Offline Tapsnap
« Reply #6 on: November 07, 2017, 11:22:26 am »
PT is Power transformer; what's PA?
« Reply #7 on: November 07, 2017, 12:32:26 pm »
PA = Power amp (section) in your case just the big tube, if it were a PP (push-pull 2 tube) then the PI (phase invertor) should be included as part of the PA section.
Offline Tapsnap
« Reply #8 on: November 07, 2017, 01:05:05 pm »
So, to clarify, you're saying  that the rectifier, the filter caps and their resistors should all ground to the same place as the grounds of the power tube which is a single lug mounted to the chassis near the power transformer. Then the grounding wires connected to the preamp, the volume and the tone, all ground to the input jack, which is also connected to the chassis but away from the power transformer. Is that right?
« Last Edit: November 07, 2017, 01:11:15 pm by Tapsnap »
« Reply #9 on: November 07, 2017, 08:27:55 pm »
Is that right?
yup
here's how I would split up the grounds, red pre, blue power
EDIT, also move your filament wires away from everybody, best you can, tuck along the edge of the chassis
Offline Tapsnap
« Reply #10 on: November 07, 2017, 10:21:29 pm »
OK, I get it now. Thanks. I can't wait to try it out. I'll let you know how it goes.
« Reply #11 on: November 08, 2017, 08:42:49 am »
Take your time, think each section through, solder well, the more "front end" time you devote the more flawless jamming can be done later :laugh:
« Reply #12 on: November 08, 2017, 09:39:30 pm »
> Sometimes the amp works at full volume ...., then suddenly it cuts to half the volume
This is almost certainly a Bad Joint. Find and fix it; then we can talk about the buzz.
Offline Tapsnap
« Reply #13 on: November 10, 2017, 02:13:17 pm »
Well, I read the "grounding" page on Aiken Amps website and I now I think have a much better understanding of this whole grounding subject. Unfortunately, I had to conclude that I had to redesign the entire circuit board. So here is what I came up with.
Nothing is soldered yet so I can easily make some adjustments. I put in an extra filter cap which I may use if it is still too noisy, but will leave out initially,. The grounding for the preamp centers at "B" and the output and power supply, centers at "A
Offline Tapsnap
« Reply #14 on: November 10, 2017, 05:54:40 pm »
Actually, that's completely wrong. Ignore my last post.
« Reply #15 on: November 10, 2017, 08:39:32 pm »
dually ignored :icon_biggrin:
just take your time, double-check, ohm, you'll be jamming soon :guitar1
« Reply #16 on: November 11, 2017, 10:48:01 am »
Here's another good read on grounding, if you haven't read it yet. It's from Merlin's web site, he is a member here and drops in now and then.
http://www.valvewizard.co.uk/Grounding.html
