September 19, 2026, 01:54:43 am
Hoffman Amps Forum image Author Topic: is this normal?  (Read 5194 times)
Offline ernie_jr
  • gimme a banana
is this normal?
« on: November 20, 2017, 01:43:20 pm »
Hello all,
It has been awhile. Started rebuilding a SUNN 200s. Using sand rectofiers instead of 5ar4. The question I have is,
the tranny puts out 875 volts ac across the 2 red wires which is about right. Off the diodes I only get 400 volts dc.
There are no filter caps installed yet. I was expecting some where aroud 570 volts dc. Is this because the filter caps
are not yethooked up?
Thanks,
Ernie
Re: is this normal?
« Reply #1 on: November 20, 2017, 01:46:39 pm »
Is this because the filter caps are not yet hooked up?
yes
Offline ernie_jr
  • gimme a banana
Re: is this normal?
« Reply #2 on: November 20, 2017, 01:50:28 pm »
Thanks for the quick reply. Time to keep on building and no need to trouble shoot yet
Ernie
Re: is this normal?
« Reply #3 on: November 20, 2017, 04:27:30 pm »
1.414 applies WITH cap.
No-cap, the Average DC will be 0.9 times the AC RMS.
875/2 is 437V each side.
0.9 times 437V is 394V average (very lumpy) DC.
Offline 92Volts
Re: is this normal?
« Reply #4 on: November 20, 2017, 07:22:14 pm »
Where does 0.9 come from? It seems like average and RMS mean the same thing and on average the DC is simply the AC, rectified. There will be diode losses but surely this can't be standardized across different voltages (and would generally be low in the context of a tube amp's hundreds of volts)?
Re: is this normal?
« Reply #5 on: November 20, 2017, 08:35:25 pm »
Vp = 1.414Vrms
Vavg = .637Vp
Vavg = .637 x 1.414Vrms
Vavg = .9Vrms
http://www.rfcafe.com/references/electrical/sinewave-voltage-conversion.htm
Re: is this normal?
« Reply #6 on: November 21, 2017, 06:56:10 pm »
No.
Homework: show I am wrong or right.
