September 14, 2026, 03:20:01 am
Hoffman Amps Forum image Author Topic: 5E8a builds  (Read 7144 times)
Offline crashtm1
5E8a builds
« on: November 29, 2017, 06:28:26 am »
Has anyone built a high powered version?
Specifically the 5E8a , not 5f8.
How about with a PPIMV?
Offline centervolume
Re: 5E8a builds
« Reply #1 on: December 05, 2017, 08:33:57 pm »
Yes, I built a 3-12 version 4x5881 twin circuit 5F8-A
Offline crashtm1
Re: 5E8a builds
« Reply #2 on: December 31, 2017, 08:12:07 pm »
Digging through my stash, I found these two beauties. A Mono tweed bassman PT (340v) and a MM JT4550-G4 (380v).. I've emailed MM for the specs and diagram.
What difference will I see between these two? More power? Tone?
Offline drew
Re: 5E8a builds
« Reply #3 on: December 31, 2017, 10:22:05 pm »
What "high powered" configuration are you contemplating? Both of those PTs are for amps that use a pair, not a quad, of power tubes.
Re: the PPIMV question, http://el34world.com/Forum/index.php?topic=15984.0 may be useful.
Offline crashtm1
Re: 5E8a builds
« Reply #4 on: January 01, 2018, 12:32:53 pm »
I'm currently building low power tweed twin 5E8a. I had considered dumping the 2 rectifier tubes and converting it to a 4x6L6 amp with SS rectifier. But for now I'm going to stay with the original layout.
Offline crashtm1
Re: 5E8a builds
« Reply #5 on: January 02, 2018, 08:30:43 pm »
Can someone explain the B+ voltage change notes at the bottom?
Does this mean the B+ changes depending on the rectifier?
Re: 5E8a builds
« Reply #6 on: January 02, 2018, 08:46:46 pm »
Bottom of what? If you are referencing some schematic post a link so we can see it too.
Offline crashtm1
Re: 5E8a builds
« Reply #7 on: January 02, 2018, 10:12:30 pm »
Been a long day..
Offline Joel
Re: 5E8a builds
« Reply #8 on: January 02, 2018, 10:43:31 pm »
Tube rectifiers are not as efficient as solid state rectifiers.  So yes, the B+ changes depending on what sort of rectifier device/s you are using.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline crashtm1
Re: 5E8a builds
« Reply #9 on: January 05, 2018, 05:18:33 am »
Solid state.
Offline ac427v
Re: 5E8a builds
« Reply #10 on: January 05, 2018, 08:06:13 am »
If that is a MOJO 752 it would have a solid state rectified B+ of around 500 volts! The 5E8-A schematic shows 400 volts to two 6L6G power tubes. A 5R4GYB tube rectifier would get you a lot closer to the original voltage. I also see that this Twin needs an uncommon (for guitar amp) choke because it must handle the entire high voltage load, not just the preamp tubes and power tube screens. I bet someone on this forum has found a suitable Hammond choke. I think it would be a very sweet amp if you can get close to original voltages.
Craig
