September 17, 2026, 08:16:55 am
Hoffman Amps Forum image Author Topic: Someone has a 6BM8 (ECL82) SE Amp (turret or Eyelet Board) Layout to share ?  (Read 9694 times)
I want try to plan a Turret Layout for the Gibson GA-5T Skylark '61 (5Y3GT - 6BM8 - 12AX7)
and .... as it is more easy to plagiarize than to invent I'm looking for a Board Layout of a 6BM8 based SE Amp
to be used as a start point to plan the GA-5T Skylark Layout
Offline VMS
Good pictures here, text says EL-84 power tube but if you look at the pictures the power tube is clearly ECL82
http://truevintageguitar.com/inventory/1960-gibson-ga-5t-skylark-tremolo/
hope this helps
Many Thanks VMS
I've also some other photo of the original, one very good
However I'm thinking to a new layout (not an exact clone), one where all components are on the board
so I was hoping to find a Board Layout of any amplifier that uses 6BM8 as to be used as a base
the photo I've is very good, but some parts of the connections are unreadable
Meanwhile I've find this GA-1RVT Layout that isn't the best option but I can use if I don't find other better option
« Last Edit: December 03, 2017, 06:19:24 pm by kagliostro »
Offline VMS
It's probably difficult to find layout with same tremolo. Here is one more gut shot of ga-1rt amp that has same ecl82 section. It shouldn't be too hard to make a layout comparing all these pictures you have now.
https://reverb.com/item/2278257-vintage-1961-maestro-ga-1rt-reverb-echo-tube-amp-gibson-made
Good inside photo  :thumbsup: :thumbsup:
Thanks VMS
Offline VMS
Little off topic and don't remember if i have talked about this before but a while ago i was thinking that amp using only 6bm8 tubes could be a fun project. I draw this schematic then using preamp from svetlana datasheet, vox type tone stack and power amp from dynacord kv10.
Ciao VMS
I'm not sure about, but to me seems you or one other guy posted something similar some time ago
Offline VMS
might have been me, i don't remember what i post here half the time  :laugh:
Offline MFowler
In the Hoffman .sch library there is a GA-5T layout and schematic. Also two more that say with mods.
  :BangHead:
I didn't recognized that there was a Layout on the .sch library
Many Thanks MFowler
I'll give a look also to the other versions with mods
EDIT:
I need help, I'm not able to find where are those files  :w2: :dontknow: , can you post the link to the page ?
I discovered I've all those file  on my archive since some years ago  :bump1: , but I'm not able to find them on the site pages
« Last Edit: December 05, 2017, 08:49:51 am by kagliostro »
Offline MFowler
Yes some more that say mods GA-5T
Thanks for the files, but where they are in the forum ?
Offline MFowler
The ones I uploaded were in my Hoffman files on my computer collected over the years.
I tried to find them on the Forum but could not locate them.
Mark
Many Thanks Steve
Some time ago (may be years) there was a compressed file with the .sch library of schematics
seems that it is no longer present on the forum
Offline svejkist
Here is a GA-1RT-1 layout with a few mods (SS rectifier, LED oscillator bias, some values, no vestigial reverb).
« Last Edit: December 06, 2017, 10:35:45 am by svejkist »
Many Thanks also to you Svejkist :thumbsup:
do you know the origin of that layout ?
Offline svejkist
I drew it years ago. The second layout I ever did, so maybe not ideal. But the amps I built from it worked fine. I have the DIYLC file, but it wouldn't let me attach it here. If you want me to email it, PM me.
« Last Edit: December 06, 2017, 01:53:40 pm by svejkist »
Thanks for the answer
Not to refuse your offer, but what you posted is enough
p.s.: To solve problems about files that are not allowed to be post, compress it and post the compressed file
Offline svejkist
Thanks, I wondered if that would work, but didn't see zip, gz etc in the allowed file types. Could probably also just change the extension.
"Allowed file types: doc, gif, jpg, pdf, png, txt, zip, sch, jsch, xls, xlsx, csv, dxf, vsd, vss"
« Last Edit: December 06, 2017, 09:37:23 pm by PRR »
