September 17, 2026, 06:13:00 am
Hoffman Amps Forum image Author Topic: Old 60’s Gibson Titan Medalist transformer question  (Read 5079 times)
Offline drumguy
« on: December 05, 2017, 10:18:44 am »
The power transformer in this amp is fried and looking for a replacement.
The part number is TF-135-P. The schematic ilooks to be hand written and
really blurry. The PT specs from it seem to be....
Primary 0-120
Secondary HV 330-46-0-330
Fil 3.15-0-3.15
660v CT
Does anyone know if these are accurate?
I can’t find spec info on this transformer anywhere.
Offline drumguy
Re: Old 60’s Gibson Titan Medalist transformer question
« Reply #1 on: December 05, 2017, 10:28:59 am »
I’ve contacted a transformer builder and the specks they had on file were...
Primary 0-120
Secondary HV 380-55-0-380
Fil 3.15-0-3.15
760v CT
 These were no load measurements but still seemed a bit hot compared
to what the schematic seems to read.
« Reply #2 on: December 05, 2017, 10:45:25 am »
Primary 0-120
Fil 3.15-0-3.15
660v CT
I'd use this info. It matches the following schematic.
Does your amp have four 6L6s? If so, here's the schematic...
     http://el34world.com/charts/Schematics/files/gibson/Gibson_medalist_6L6_quartet_titan.pdf
« Reply #3 on: December 05, 2017, 10:49:11 am »
I'd use this info.
+1
a quick look I come up with a Hammond 290CX as close  I didn't add up current to see if 4A is close enough
Offline drumguy
« Reply #4 on: December 05, 2017, 11:35:14 am »
Awesome, thanks guys!
« Reply #5 on: December 05, 2017, 01:07:29 pm »
that's a twin reverb class amp - 80-100W. a 290CX will have a short life. with the original, the schematic indicates that B+ is 425V from a 660VCT coil. with those numbers, that seems like a heavily loaded PT. all depends on bias as well and 46V would run the 6L6 a bit warmer than fender did. 400-500mA PT is what you need for that amp.
http://www.classictone.net/40-18069.pdf
the classictone in the link above requires a FWB. read page of that spec sheet for more B+ options.
« Reply #6 on: December 05, 2017, 01:20:39 pm »
If you are restoring that amp it's probably important to get a replacement that will fit the original layout, especially if a laydown PT is required.
« Reply #7 on: December 05, 2017, 07:01:32 pm »
15% high NO-load is about just what we expect for a transformer like this.
Agree this is a 80+ Watt four-6L6 amp, and a two-6L6 PT won't be happy.
Offline drumguy
« Reply #8 on: December 06, 2017, 12:26:54 am »
Yes, good point!
I would like to be able to just bolt the new one right on.
Primary 0-120
Fil 3.15-0-3.15
660v CT
So should I order with the following as loaded specs?
Primary 0-120
Fil 3.15-0-3.15
660v CT
« Reply #9 on: December 06, 2017, 07:21:10 am »
That's what I'd do. Better carefully measure the mounting bolt spacing dimensions too.
Offline drumguy
« Reply #10 on: December 06, 2017, 09:14:20 am »
Ok, will do! Thanks!
