July 25, 2026, 12:58:06 pm
Hoffman Amps Forum image Author Topic: Speaker baffle attachment methods  (Read 51473 times)
Offline Apexelectric
Re: Speaker baffle attachment methods
« Reply #50 on: January 12, 2018, 07:22:28 am »
One down and one to go. Need to break in the speakers a little but sounds great so far. I took a short cut with the back panel and didn’t cut the holes in the bottom panel, bassman style. Not sure how much difference it would make?
It's never a dumb question if it prevents a dumb mistake.
« Reply #51 on: January 12, 2018, 10:43:18 am »
Very nice looking builds.  Congrats!
« Reply #52 on: January 12, 2018, 02:50:49 pm »
 :thumbsup:
« Reply #53 on: January 13, 2018, 01:23:11 pm »
Looks great!  :icon_biggrin:
Offline madnis
« Reply #54 on: January 13, 2018, 02:25:30 pm »
VERY NICE INDEED!
So...
Floating front baffle, yes/no?
front load?
I like (multiple) options where they can be
implemented, i.e. the dipole (open back),
ported (the bass reflex) and sealed (the infinite baffle).
etc.
Are you going to lacquer the crap
out of it?  :wink:
« Last Edit: January 13, 2018, 02:32:17 pm by madnis »
« Reply #55 on: January 13, 2018, 06:51:21 pm »
Floating baffle, rear load. Not sure on the lacquer, thought about it. Need to get it out for a concert next weekend so probably won’t have time till a later date to do it if I do.
Offline bnwitt
  • Crankin' out the tone.
« Reply #56 on: January 27, 2018, 05:56:00 pm »
I put Zinser Bullseye amber shellac on all of my tweeds and then lacquer  Makes them look great and protects the tweed a bit from water and fraying.
« Last Edit: January 27, 2018, 06:03:32 pm by bnwitt »
« Reply #57 on: January 28, 2018, 08:00:42 am »
How many coats of each one do you apply?
« Reply #58 on: January 28, 2018, 09:32:44 am »
I'm also fond of Zinser. Brush on one coat of Amber shellac (mixed 50/50 with denatured alcohol). Very easy to apply and dries fast. Brush on additional coats if you want it a bit darker. I've never needed more than two coats of Amber. Once the color tone is what you want, switch to Zinser clear shellac (mixed 50/50 with denatured alcohol) for additional top coats. I'm usually happy with a total of four coats. The beauty of shellac is that years later you can brush on a renew coat. The fresh coat melts into the old coats and looks good as new.
These two tweeds have Zinser on them. The one on the left has two coats of amber and two coats of clear. The one on the right has three coats of clear. A couple years later I added two coats of amber to the one on the right. Now they look the same.
« Reply #59 on: January 28, 2018, 10:27:51 am »
Sounds easy enough. I think I'll give it a shot. I don't imagine its a low odor product? If not, it might have to wait till the weather warms up so I can do it outside.
Quick story:
I rented this rig to a friend of mine who runs the concert hall at our local college for a Los Lobos show. They requested a Bassman be available for their rhythm player, which was one of the main reasons I built this thing in the first place. They ran it through sound check and had it ready to go. Right after the opening act, the did another quick sound check and decided right before the show started to sub it for a Hot Rod DeVille. :w2:
The bight side is that their stage engineer left his card on my amp so maybe there's a silver lining.
Oh well, better luck next time.
Thanks guys!
Offline bnwitt
« Reply #60 on: January 28, 2018, 02:14:23 pm »
Well Sluckey answered all of your questions regarding the shellac application.  The only thing I do differently is after I get the tone just right with the amber shellac I then finish the cabinet with satin Lacquer rather than clear shellac.  Shellac is not very water resistant and I want a final finish that can take a bit of moisture since some people like to set drinks and other wet thangs on the amps I build for them. :cussing:
Steve, that DR on the left looks sweet! :worthy1:
Offline bnwitt
« Reply #61 on: January 28, 2018, 02:23:44 pm »
...they did another quick sound check and decided right before the show started to sub it for a Hot Rod DeVille. :w2:
Probably just because the player is used to a particular dialed in amp setting and didn't want to tweak a new one.
Here's my short story, I displayed a Hoffman 5E3 and a 1X15 Hoffman AB763 (Vibroverb) at the 2008 Winter NAMM years ago in the CE Distribution Jensen speaker booth as they sent an all call out to their known amp building customers for amps using the new Jensen speakers.  During the show I got a call from John Fogerty's equipment manager asking me if I could supply two of them for his upcoming tour which was starting in a few weeks.  I told him I couldn't build two that fast and I missed out on that deal. :sad2:  In the photo below that's my Duke 55 (5E3) front and center.
« Reply #62 on: January 28, 2018, 02:29:51 pm »
That’s a bummer.
Offline bnwitt
« Reply #63 on: January 28, 2018, 02:34:09 pm »
That’s a bummer.
Nah.  Probably saved me thousands of dollars going further down the amp building business rabbit hole. :laugh:
« Reply #64 on: January 28, 2018, 05:50:56 pm »
My experience is that the typical guitarist will very likely choose a current production, "modern" amp.  Realistically, I suspect many guitarists know hardly anything about amps.
Offline bnwitt
« Reply #65 on: January 29, 2018, 07:38:28 am »
The one thing most seem to know is that cheaper PCB based Chinese built amps are a much better value than a hand wired boutique amp. :l2:
« Reply #66 on: February 14, 2018, 06:04:30 am »
I like pumpkin tweed. If you don't do not use amber. Clear brush on lacquer works well too. Still reduce or thin with  thinner.
