August 29, 2026, 04:00:39 pm
Hoffman Amps Forum image Author Topic: General consensus on IC caps, both in power and signal use.  (Read 5091 times)
Offline SolidStateCircuitReject
« on: December 13, 2017, 01:53:08 am »
What is the general consensus on IC caps? In my very quick try out of their axial polypropylene signal caps I found them to be perfectly fine for high gain amp use - bright, clear and not harsh - but this was a very quick tryout. I have also tried Sozo (originals), Mallory, and Xicon polypropylenes - the Xicons were what ultimately stayed (again a high gain circuit) but I was curious what people think about them in terms of their signal and for power filtering use...
I usually hear people slag them, but I saw no issue with them, though I can imagine if they were used in a classic/vintage design that they would not make the cut for sure.
Offline 92Volts
Re: General consensus on IC caps, both in power and signal use.
« Reply #1 on: December 13, 2017, 08:56:17 am »
I've always built with the cheapest modern film caps on Mouser. I've burned myself by getting ones that are physically hard to install (also done this to myself with "snap-in" electrolytic filter caps-- made them work but regretted the purchase). But I've always been happy with the sound.
Obviously you may hear other opinions, and I haven't experimented to know if something else is better.
But I can confidently say off-brand capacitors won't make your amp sound like garbage... the effect they have on the sound is secondary to circuit design by miles.
« Reply #2 on: December 18, 2017, 08:56:53 am »
I personally won't use IC brand electrolytic caps - I've come across too many modern Fender amps with these caps suffering from failure/reliability issues. The attachment is case in point - this Tonemaster came in blowing fuses recently, and when I opened the doghouse I found these bulging beasties. Replacing them cured the problem.
« Last Edit: December 18, 2017, 09:01:21 am by tubeswell »
« Reply #3 on: December 18, 2017, 10:23:55 am »
I'm with Tubeswell - I've seen failures of IC filter caps in Fenders. Why use them when F&Ts are readily available?
