September 14, 2026, 02:00:22 pm
Hoffman Amps Forum image Author Topic: Can you bypass the reverb and extra gainstage on a deluxe reverb?  (Read 5759 times)
Offline Toxophilite
Is it possible , via a switch to bypass the reverb and extra gain stage on a deluxe reverb? essentially switching it a straight deluxe
« Last Edit: December 21, 2017, 06:55:25 pm by Toxophilite »
Re: Can you bypass the reverb and extra gainstage on a deluxe reverb?
« Reply #1 on: December 21, 2017, 07:02:21 pm »
Sure.
Offline Toxophilite
« Reply #2 on: December 21, 2017, 07:50:37 pm »
Cool! Thanks. I might play around with that idea as I remember one of my first non reverb deluxe builds being a really nice sounding amp.
« Reply #3 on: December 21, 2017, 08:26:24 pm »
I'm working on a schematic but I'll have to finish tomorrow morning when I'm fresh.
Offline Toxophilite
« Reply #4 on: December 21, 2017, 11:20:33 pm »
Wow! Very appreciated. It's a one channel deluxe reverb build
I guess one would need a double throw switch, probably interrupting after the blocking caps after the second gain stage and the gain stage after the reverb (before the PI) Maybe a push pull switch on the actual reverb pot.
Offline Toxophilite
« Reply #5 on: December 22, 2017, 03:11:18 am »
like this maybe?
Quick rough
(I just noticed that this schematic might be missing a 220K resistor to ground just before the PI)
double throw switch - blue
preamp side - red lines
PI side - green lines
« Last Edit: December 22, 2017, 03:15:15 am by Toxophilite »
« Reply #6 on: December 22, 2017, 06:15:36 am »
That should work.
So, you don't have an opto-coupler (roach) type tremolo circuit like a real AB763?
Offline Toxophilite
« Reply #7 on: December 22, 2017, 10:48:49 am »
No
This is one of my builds and I've been using the bias vary
However a fellow was telling me it's easy to make an opto-coupler
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #8 on: December 22, 2017, 07:05:25 pm »
Attached is a variation on your theme.
There are some errors on your schematic that you will probably notice when you actually build the amp.
Offline Toxophilite
« Reply #9 on: December 24, 2017, 03:54:39 pm »
Thanks. I appreciate that
This amp is built(as well as a few others), however there are likely errors in my schematic , as well some things have been purposefully changed.
