September 14, 2026, 07:46:58 am
Hoffman Amps Forum image Author Topic: Ampeg B25B Blowing the fuse  (Read 6143 times)
Offline TerryD
« on: December 22, 2017, 10:31:40 am »
I'm used to working on Old Fenders which is, as you know, fairly simply.  This amp is a friend of mines.  I see one cap with an outside crack or slice.  I was going to change all the electrolytic caps but these are in the cans.  Any tips on doing those.  Also tips on overhauling this??
Also both transformers have a good deal of rust on the outside.
Please be simple.  Probably shouldn't be doing this, but I have done some extensive repair with your help a number of times but mostly on Fenders.
Thanks, Terry
« Last Edit: December 22, 2017, 03:41:47 pm by TerryD »
Re: Ampeg B25B Blowing the fuse
« Reply #1 on: December 22, 2017, 11:05:59 am »
are they the twist lock soldered type?  If so, mark all the wires, WELL, take a pair of dikes and cut the "tab" at the cap side, then just heat up the solder, suck n pry the little tabs out.
same as fenders, get the PS working without tubes, start adding tubes, fix each section as you go, keep an eye out for bad wires n solder joints and lead dress, and....
walla, fixed :icon_biggrin:
« Reply #2 on: December 22, 2017, 11:28:01 am »
Find out why it's blowing the fuse before you start shotgunning parts. Use the same troubleshooting techniques you would use on any Fender.
« Reply #3 on: December 22, 2017, 11:38:40 am »
Offline TerryD
« Reply #4 on: December 22, 2017, 03:37:03 pm »
ALSO  I see this amp does not have the 5AR4 tube rectifier.  does that make it a different ?
I only see one fuse?
Other than this the front "looks" like an Ampeg B25B  There is no name that I can see.
Not only is there a lot of rust on the transformers, there seems to be rust or corrosion everywhere...like on the solder joints etc.
« Last Edit: December 22, 2017, 03:43:00 pm by TerryD »
« Reply #5 on: December 22, 2017, 07:41:12 pm »
The plan Silvergun linked has four. Ampeg did sometimes draw one thing and build another.
The rust is extra mojo. It has NO effect on the transformer until spoonfuls of rust are missing.
Corruption on joints is less innocent. They may all need to be re-done before you get all the crap-outs out.
« Reply #6 on: December 22, 2017, 08:33:34 pm »
I'd start there, don't even need meters, surfing, maybe :icon_biggrin:
Offline davidwpack
    • My music on reverbnation
« Reply #7 on: December 23, 2017, 08:03:45 am »
I rebuilt 2 of them recently. I had one can and a couple of individual caps The only problem I ran into was that all the grounds went to the can so I had to make a ground bus. The inside of the chassis is also painted so I sanded a couple tiny spots with the Dremel for the screws to make sure I had good contact. I think I used 50/50 uf for the can.
