September 15, 2026, 02:30:17 am
Hoffman Amps Forum image Author Topic: big film-caps, suitable for power supply, affordable  (Read 7561 times)
« on: December 22, 2017, 07:13:42 pm »
https://www.mouser.com/productdetail/epcos-tdk/b32778p6506k000
B32778P6506K000
Mfr.: EPCOS / TDK
Film Capacitors 50uF 10% 630Vdc   AEC-Q200 LS 52.5MM
B32778P6506K000 Datasheet
Length: 57.5 mm Width: 35 mm Height: 50 mm
$10.94
You can get 50uFd 450V e-cap for less. It may be a little smaller. It may last decades or just a few years.
The film-cap is likely to last a lifetime, especially in 500V 300mA filter duty.
Offline bnwitt
  • Crankin' out the tone.
Re: big film-caps, suitable for power supply, affordable
« Reply #1 on: January 01, 2018, 07:33:58 pm »
Why are there 4 leads? Nevermind.  I just read the data sheet.  Parallel leads
« Last Edit: January 01, 2018, 07:46:59 pm by bnwitt »
« Reply #2 on: January 03, 2018, 11:12:34 pm »
I had assumed, being tall and heavy, if you solder it 2-leg to a PCB it would fail a shake-test (rip off the PCB).
For our purposes, I'd glue a few in a corner and solder to the legs. They should out-live us all, so glue is not a major sin.
« Reply #3 on: January 05, 2018, 11:27:07 am »
I've toyed with using motor run caps:  https://www.ebay.com/itm/50uF-MFD-370V-440V-VAC-Oil-Filled-Motor-Run-Capacitor-CBB65-50x100mm/272877458990?hash=item3f88c3962e:g:fgMAAOSwEIFZ2FPt
They can be anywhere form about $8 to $35.  But they're huge: 100mm or more tall; 50mm or more wide.  Also the can is live if stacked, say for voltage doubling. The TDK plastic caps do seem appealing.
Offline lego4040
« Reply #4 on: January 05, 2018, 07:15:42 pm »
JJ I have loads of those start/Run caps, some as big as car batteries. I never thought about using them, I figured the electric would be dirty coming out. I can atest that i have caps in HVAC units from the 80’s still going.
« Reply #5 on: January 05, 2018, 09:34:04 pm »
My research - on hi-i forums, tells me motor run caps are desirable.  Supposedly caps in oil, even as filter caps, are good for bass response.
« Reply #6 on: January 06, 2018, 01:52:58 pm »
Another link, more choices: Mouser big film caps, 20uFd
You can try to modify the search for 40uFd etc.
FFLI6B3007KJE 800v 3,000uF will keep your VT-40 from sagging ($485.68).
FE52N6J0506KB 550V 50uF $7.29 will serve a lot of amps and may never die.
« Last Edit: January 06, 2018, 01:58:17 pm by PRR »
« Reply #7 on: January 06, 2018, 03:19:43 pm »
I got a triplet of 10,000uF 450VDC if you're interested, they're about a foot tall n 4" dia. so you might need a spare cap, cab :icon_biggrin:
« Reply #8 on: January 06, 2018, 03:41:19 pm »
FWIW I've also been thinking about ceiling fan motor caps, 'cause I like l low value K bypass caps:  https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2053587.m570.l1313.TR10.TRC1.A0.H0.Xceiling+fan+capacitor.TRS0&_nkw=ceiling+fan+capacitor&_sacat=0
Offline lego4040
« Reply #9 on: January 06, 2018, 06:34:41 pm »
We all use box capacitors in pedal builds these days and there is lots of options especially in choice of manufacturers. Why dont we use them more in amp builds? I think red Wima’s, Blue Epco’s, etc....would look great on these boards from Doug. Ok, they have short leads but you can work around that one
« Reply #10 on: January 06, 2018, 07:56:28 pm »
Voltage probably limits some :dontknow:
and black n gold FT caps look real pretty and they have an analog shape :icon_biggrin:
