September 14, 2026, 11:45:27 am
Hoffman Amps Forum image Author Topic: 5E3 Capacitor question  (Read 4629 times)
Offline GLFSHNT
« on: December 24, 2017, 12:06:45 pm »
On the 5E3  Cap 10 is a filter cap?
What does it do?
My 5E3 build has been working great since completion. I opened it up to swap out C1 and 2 to tighten up the low end.
I noticed that Cap 10 had disintegrated. Up on inspection it had been installed reverse polarity. (my bad...)  I think it came apart shortly after I turned it on. I never noticed.... I have been playing the amp for a few weeks -mostly very low volume. I cannot see any issues. Coupd that be part of the low end flub?
Thanks all.
Re: 5E3 Capacitor question
« Reply #1 on: December 24, 2017, 01:04:14 pm »
C10 is your 1st tap filter cap, shoulda made a nice POP when it went.  I would expect more hum than flab, which way did you go with C1 & 2?  they are "to taste" kinda caps, I like 2-10 for C1, then C5 anywhere from 10 - 22.  Speakers are a pretty good source for flab, might try a bunch n see if that helps
Offline GLFSHNT
« Reply #2 on: December 24, 2017, 02:02:55 pm »
That's why the amp hums so much at any volume....
C1 and and 2 are .1 right now.  As this is my first build and kind of a test bed. I thought I might add a small switch on the chassis next to the output jacks that would allow me to switch between different caps on 1 and 2.
---Maybe I just have the tinker bug and feel the need to mess with it.....
« Reply #3 on: December 24, 2017, 02:09:31 pm »
You definitely need to replace C10 to get rid of the hum.
