September 13, 2026, 08:04:23 pm
Hoffman Amps Forum image Author Topic: Looking for good breadboard for constructing effects pedals  (Read 12108 times)
Offline bnwitt
  • Crankin' out the tone.
« on: January 01, 2018, 04:03:22 pm »
Do any of you pedal builders have a suggestion for a good quality reasonably priced breadboard that would be suitable for building effects pedals?
Thanks in advance,
Barry
« Last Edit: January 01, 2018, 04:48:54 pm by sluckey »
Offline bnwitt
Re: Looking for good breadboard for constructing effects pedals
« Reply #2 on: January 01, 2018, 05:26:25 pm »
Thank you Steve. :smiley:
« Reply #3 on: January 03, 2018, 04:35:28 pm »
Here's a breadboard I made back in the '70s. I did mostly digital stuff on it but analog would be easy too. Might give you some more ideas.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #4 on: January 04, 2018, 09:00:43 am »
This is what I got, I think something of this size will work for most pedals.
https://soundcloud.com/ukiuki
« Reply #5 on: January 04, 2018, 01:12:37 pm »
Barry,
That board Sluckey posted the photo is the one I have now.  It looks a little different now, but functions the same.  Sluckey had it powered by basically a wall wart to a RCA input.  I did change this because I run the boards from dedicated power supplies.  He did not say he sold it to me, but I have it.
FYI, I do not care for any more than 3 side by side boards, I prefer multiple boards so I don't have to rebuild every circuit.  For instance, I keep a preamp pedal board and an effects board like simply overdrive or fuzz and I can easily knock up a few versions and switch them back and fourth.
All I do is cut Corian and get joist hangers, the ones with holes in them.  These can be bolted to the Corian and the breadboards simply stick.  The holes are great for jacks, pots and switches.
Sort of like this except mine are built a bit cleaner looking.
Offline bnwitt
« Reply #6 on: January 26, 2018, 10:35:50 am »
Wow gentlemen.  Thank you for all of the info.
