September 13, 2026, 10:07:38 pm
Hoffman Amps Forum image Author Topic: JCM 800 Bass Amp Loud cracklilng  (Read 4649 times)
Offline dpm309
    • Matthews Amps
« on: January 03, 2018, 11:47:17 am »
I have a Marshall JCM 800 Bass series, 100 watt that has a very loud crackling when it is powered up, even with nothing plugged into it and the volume turned all the way down. Someone replaced one of the Cliff jacks (looked like cold solder joints) so I resoldered it with no luck. I plugged a dummy plug into it and it reduced the crackling a bit. Removed it and all works fine. The jack looks brand new so I am wondering if it might be defective or the PCB was damaged. I don't have a spare cliff jack that I can replace it with. Any suggestions?
Re: JCM 800 Bass Amp Loud cracklilng
« Reply #1 on: January 03, 2018, 12:35:13 pm »
Any suggestions?
any room to temp-in a switchcraft and wire?
any "spare" cliffs that you can "borrow" from, say, send/return, line out, etc.?
« Reply #2 on: January 03, 2018, 01:01:06 pm »
Pull little tubes starting at the preamp and working toward the PI. Which tube pull kills the crackle?
Offline dpm309
    • Matthews Amps
« Reply #3 on: January 03, 2018, 03:54:27 pm »
Well, it turns out that whoever installed the new cliff jack, bunged up the traces on the PCB. Cleaned everything up and re-soldered the jack and now it works like a charm. Second time I have worked on this amp. The first time the owner installed a new power tube socket and had wired it incorrectly. Every pin was off by 1! Hope this teaches him a lesson to not try any more repairs on his own.
Thanks for the input and sorry if I wasted anybody's time on this. I should have known better.
« Reply #4 on: January 03, 2018, 04:32:29 pm »
why not? how else is your friend supposed to gain experience?
respectfully,
