October 06, 2026, 03:38:52 am
Hoffman Amps Forum image Author Topic: Channel switching question  (Read 4480 times)
Offline VMS
« on: January 09, 2018, 04:49:50 pm »
Can the power source for the relays be put on footswitch enclosure and how much relays usually need current?
I was thinking maybe batteries or pedalpower with 12vdc output
Re: Channel switching question
« Reply #1 on: January 09, 2018, 05:05:39 pm »
where's the relay gonna be?, if it's in the amp should be fine, if you route signals to a pedal with relay that might get ugly.
this is from doug's relay page;
The relay has a 5 volt coil rated at 40ma
Offline dennyg
  • Hillbilly in Philly
« Reply #2 on: January 09, 2018, 05:22:00 pm »
Like Shooter said, running the power from a board back to the amp isn't ideal.  The only relays I've used are the one's Doug sells - I think they draw around 20-30ma each when engaged.  It's very easy to tap your 6.3V heater supply to feed a 5V regulated relay supply, and Doug's board is small, or you could build the circuit on a small piece of turret or eyelet board.  You only need a bridge, 7805 regulator and large value cap (4700uf or so).  The current thru the footswitch will also power an led on/off indicator in most standard footswitch pedals.
What's last thing a hillbilly says before an untimely death?
"Hey ya'll, watch this!"
Offline VMS
« Reply #3 on: January 09, 2018, 05:47:50 pm »
Relays would be in amp. I guess i'm worried that tapping to heater supply induces noise to the circuit.
I also have this london power ERK kit that can be powered from center-tapped plate winding (my plate winding doesn't have center-tap so this is a problem maybe) or it can also be powered with -12VDC source
« Reply #4 on: January 09, 2018, 07:52:40 pm »
There is an abundance of info on relay switching here in ARCHIVES:
http://el34world.com/Forum/index.php?topic=14348.0
Maybe looking over this would be useful in making a decision?
Offline VMS
« Reply #5 on: January 10, 2018, 08:32:05 am »
Thanks guys.
I think I can use the capacitor coupling method to get the power for the ERK from the HT winding. So i'm going to try that first.
