October 07, 2026, 10:10:34 pm
Hoffman Amps Forum image Author Topic: non-insulated shielded cable?  (Read 7484 times)
Offline dennyg
  • Hillbilly in Philly
« on: January 18, 2018, 04:28:15 pm »
I accidentally ordered bunch of non-insulated, braided shield 22gauge cable.  After going thru my "awe man" moment, got me thinking that other than making sure it gets firmly placed away from any potential voltage contacts, that laying it against the chassis would provide excellent shielding - and without the trouble of soldering in the ground lead for the shield.
I didn't even know this type of shielded cable existed, but sure does look cool.
What say ye veterans of the trade?
What's last thing a hillbilly says before an untimely death?
"Hey ya'll, watch this!"
Re: non-insulated shielded cable?
« Reply #1 on: January 18, 2018, 04:37:02 pm »
just laying it on the chassis will NOT be a good thing, ground want a really good mechanical bond.
slid some shrink-wrap over n you have insulation.  Are you sure there's not a clear enamel, shellac coating on the braid?
« Reply #2 on: January 18, 2018, 05:16:31 pm »
I am wondering that since you ground the shield only on ONE end that if it was touching the chassis in one or more places also would be problematic and/or create hum.
Online sluckey
« Reply #3 on: January 18, 2018, 05:43:51 pm »
Take a look at the reverb cables on an original Fender blackface amp.
« Reply #4 on: January 18, 2018, 06:29:24 pm »
I would just use it.
Don't let it touch live wires/lugs, of course.
« Reply #5 on: January 18, 2018, 06:31:51 pm »
Years ago it was a common type of shielded cable
and it was secured, to avoid movements, soldered in several points of the chassis and mechanics
but this didn't mean it was a good choice, I consider it a practice of the past, like grounding one leg of the heaters
Offline dennyg
« Reply #6 on: January 18, 2018, 08:50:03 pm »
Well i bought the stuff and it looks cool so I'm gonna work it into my next build.  Here's my theory on why i think it will serve it's purpose:  the connection to chassis is only for shielding, not for a ground circuit which carries current, so creating a ground loop within the shield shouldn't be an issue as long as it lays against the chassis for much of its length.  What would be problematic is if it only touched the chassis at a couple spots then the resistance between those spots could create a slight noise voltage across it.  But then again I use a star ground with only a single connection to the chassis for the entire amp circuit ground, so in theory there should be minimal ground currents flowing thru the chassis - except i guess between the safety ground and the star point.  But at the end of the day, it will either contribute to a quiet amp or not.  I'll report back in about a month when i plan to finish the next one, and it's an ultra high gainer so it'll definitely expose shielding flaws.
« Reply #7 on: January 18, 2018, 09:06:52 pm »
fender reverb tank cables were made with that type of cable.
« Reply #8 on: January 19, 2018, 01:07:24 am »
Hi guys, These local built Fi Sonic's used miles of the stuff.
There is a main buss wire that runs the length of the amp and the braid is soldered to it, so neither end is actually connected.
These amps are generally quiet at idle.
I have used this method a few times with no problems.
« Reply #9 on: January 19, 2018, 02:33:57 am »
Ciao TIMBO
a picture is worth more than a hundred words :thumbsup:
That is exactly what I was trying to say (soldered in several points of the chassis and mechanics)
« Reply #10 on: January 19, 2018, 09:36:42 am »
I will cause ground loops.  You may not notice, but they will be there and it will wait until the performance of you life, says Murphy, to squeal like a pig.  You can think about it, but don't do it.
« Reply #11 on: January 19, 2018, 09:40:25 am »
Check our Teflon Tubing on ebay or McMaster-Carr.  It is clear, tough.  Buy enough to cover the wire when you want to use it for more than a ground buss.
« Reply #12 on: January 25, 2018, 12:23:17 pm »
Yep, agree.
