October 06, 2026, 11:05:17 am
Hoffman Amps Forum image Author Topic: 6U8 vs 6U8A - is the difference only in heather Warm-Up time ?  (Read 6577 times)
Online kagliostro
« on: January 22, 2018, 02:46:22 am »
Is the difference between 6u8 and 6U8A only in heather warmup time ?
http://frank.yueksel.org/sheets/168/6/6678.pdf
https://frank.pocnet.net/sheets/049/6/6U8A.pdf
Offline VMS
Online kagliostro
Re: 6U8 vs 6U8A - is the difference only in heather Warm-Up time ?
« Reply #2 on: January 22, 2018, 02:34:18 pm »
Thanks VMS
« Reply #3 on: January 23, 2018, 03:37:40 pm »
They may be the same.
In series-string heaters it is best if all the heaters warm-up at the same rate. A standard rate was picked, and some (not all) the "A" tubes meet that spec. However the spec was picked to be similar to how most existing tubes warmed-up. I suspect only a few extreme types, or odd makers, actually had to  change their heater designs.
Huh. The magazine Popular Science ran a very fictional story/article about the change. Because it is a boring subject, the author jazzed it up with a horse-betting story and Runyon-esque slang. This may not read well if you are not an older American, but you will get the idea. "11 seconds" is a simplification; I inserted the actual spec.
Online kagliostro
« Reply #4 on: January 23, 2018, 05:11:10 pm »
Thanks PRR
I like very much your explanation (and saved the article in my archive)
