September 08, 2026, 08:06:17 pm
Hoffman Amps Forum image Author Topic: Switching between two PPIMVs  (Read 8048 times)
Offline Leevi
    • Rikstone
« on: January 24, 2018, 11:08:42 am »
Has anyone succeeded to prevent popping when switching between two PPIMV?
/Leevi
Re: Switching between two PPIMVs
« Reply #1 on: January 24, 2018, 11:22:08 am »
short of power down, switch, power on, you might be on a fools errand, but I've ran a few errands like that :icon_biggrin:
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #2 on: January 24, 2018, 11:30:03 am »
The popping comes from the buildup of current that has no path, I thought with any popping switch you can resolve the popping by putting in a significantly higher resistor to ground than the normal path, say you have 1M audio pots put in a 20M to ground so when the switch is temporarily 'open' it has a path somewhere until the switch re-engages and then you have a better path again for the signal.
IN the case of a PPIMV usually its a 220/250k dual pot or some such, so you may do fine with a 1M or so but still even higher is better, meaning the current doesn't want that at all if he PI is in circuit.
~Phil
Phil Davis
tUber Nerd =|D
Offline Leevi
    • Rikstone
« Reply #3 on: January 24, 2018, 12:24:54 pm »
The following solution is not optimal but does it pop?
/Leevi
Offline VMS
« Reply #4 on: January 24, 2018, 03:26:37 pm »
Have you tried it like this:
« Reply #5 on: January 24, 2018, 03:33:41 pm »
Ciao Risto
Your schematic has something of odd ..... why the MV to be switched are in series and not in parallel ??
also VMS schematic has something strange ......
EDIT:
I don't think this solve pop problems, but will be the way I'll swap between two different PPIMV
the switch is draw as a pair of DPDT (as to semplify the schematic) but use one 4PDT
to solve pop problems, as told, a high value resistor used in parallel to switch contacts
« Last Edit: January 24, 2018, 04:09:34 pm by kagliostro »
Offline VMS
« Reply #6 on: January 24, 2018, 04:05:50 pm »
You maybe right, how about my second attempt?
« Reply #7 on: January 24, 2018, 04:11:16 pm »
A lot better VMS :thumbsup:
But now that I've seen it better, I think that also the  other one will be doable (and only a very small part of the signal will go where you don't want)
« Last Edit: January 24, 2018, 04:15:19 pm by kagliostro »
Offline VMS
« Reply #8 on: January 24, 2018, 04:14:06 pm »
more i think about this more unsure i am on my suggestions  :dontknow:
« Reply #9 on: January 24, 2018, 04:17:16 pm »
The way I've draw the swap will exclude for sure the unused pots from the signal path
but may be also your circuit is doable without problems .......... or not  :w2: :w2:
Offline Leevi
    • Rikstone
« Reply #10 on: January 24, 2018, 11:14:06 pm »
Thanks for your proposals guys.
My schematic was not meant to be complete, the idea was just to try prevent pot and keep some kind of usable two-master system.
The basic idea was to disconnect the non-active master by isolating it from ground.
But the setting of the non-active master will still affect to the wholeness since the current partly goes through its pots.
VMS's proposal are not complete either and I see the second one better.
Franco, your proposal seems to be complete since the master are fully separated from each other
but I think it will definitely pop.
/Leevi
« Reply #11 on: January 25, 2018, 05:16:05 am »
Ciao Risto
As I told, my schematic is without any shrewdness about preventing pops, it was only to swap completely the unused PPIMV out of the path
to avoid pops you must add resistors in parallel with switch contacts (I think)
Offline VMS
« Reply #12 on: January 25, 2018, 08:13:46 am »
How about pots parallel and switch between wipers with make before break switch
Offline Leevi
    • Rikstone
« Reply #13 on: January 25, 2018, 08:53:43 am »
Do you mean something like this?
I added resistors across the switches to prevent pop.
/leevi
Offline VMS
« Reply #14 on: January 25, 2018, 11:54:48 am »
Yes something like that.
I'm just throwing ideas and hoping that the smarter forum members will chime in   :smiley:
« Reply #15 on: January 25, 2018, 02:53:59 pm »
I agree, something like that
Remember that connected and switched that way the pots are in parallel, so if you use 1M pot is like you use 500K pots
EDIT:
Don't know if this will give a different load to the previous stage because here we have AC and no DC
« Last Edit: January 25, 2018, 03:41:30 pm by kagliostro »
Offline Leevi
    • Rikstone
« Reply #16 on: January 25, 2018, 11:09:20 pm »
Yes, I have noticed that. I think two 500K pots would still work fine since the resistance will be 250K per side.
1M is probably a better choice?
Your proposal is worth to try.
/Leevi
« Reply #17 on: January 26, 2018, 04:49:41 am »
k. nailed it - no interaction between the two dual-gang pots.
use a 22M across all 4 outer poles of the switch.
« Reply #18 on: January 26, 2018, 07:54:34 am »
Ciao Peter
Are you sure ?
I was thinking that if there is a charge on the caps as to avoid pops the resistor must perform a discharge path for the instant on which the switch is acted and the cap is not connected to the wiper of the pot
Something like this
 :dontknow:  :w2: :w2:  :dontknow:
Offline Leevi
    • Rikstone
« Reply #19 on: January 26, 2018, 10:49:43 am »
Thanks guys, now there are many proposals to be tried.
I have noticed that the resistors do not fully prevent the pop especially if you use bigger resistors.
But next time I have double PPIMV case I will try one of those.
/Leevi
Offline VMS
« Reply #20 on: January 26, 2018, 12:01:25 pm »
i suggest you start with your schem on reply 13.
Less switches less potential pops and you can always double the first caps values if you're loosing to much bass
