July 28, 2026, 11:24:29 am
Hoffman Amps Forum image Author Topic: Marshall ish build issues  (Read 20387 times)
Offline Captain chunkulus
« on: February 08, 2018, 09:34:35 pm »
Hey guys, can't seem to figure out what I've done wrong with this build. It's based loosely on a marshall jvm topology. I have been over every resister, capacitor, every wire, every pinout many many times and still cannot figure out what's wrong with the amp. I'm posting a link to a video of the issues. Any help would be great.
Re: Marshall ish build issues
« Reply #1 on: February 08, 2018, 09:54:49 pm »
Reverse the wires on your output transformer.
« Reply #2 on: February 08, 2018, 10:02:58 pm »
Just tried that. No difference.
« Reply #3 on: February 08, 2018, 10:14:44 pm »
Hard to see on the video, what configuration are your input jacks?  I thought I saw some holes.  Are they mounted up? Sorry I did not have the volume up enough on the first listen.  Almost sounds like a jack needs to be retentioned on the shorting lug.  Easy stuff first.  Could also be lead dress.  Is this a proven design?  Layout?
« Reply #4 on: February 08, 2018, 10:22:53 pm »
Well, I had previously built this circuit and couldn't ever get rid of the hum so I rebuilt the preamp circuit and now it's doing what it's doing. When I get a chance, I will draw a schematic for the circuit and post it. I have tried several  different input options. It sounds somewhay like grounding issues but I haven't been able to find anything wrong. I have used a continuity meter and traced Eveything from point to point and Eveything is wired to the places they should be. Minus a few circuit tweets, this is pretty much a copy of the high gain marshall jvm circuit if that helps. I have tried using chop sticks while the amp is on to move signal wires around to see if something changed but little to no difference.
« Reply #5 on: February 08, 2018, 10:24:53 pm »
How many input jacks do you have?
« Reply #6 on: February 08, 2018, 10:30:42 pm »
Just one. One Meg to ground, 1k, .047uf, 100pf to ground, 1 Meg to ground, 1k to input.
« Reply #7 on: February 08, 2018, 10:34:13 pm »
FX loop?
« Reply #8 on: February 08, 2018, 10:36:47 pm »
Input picture
« Reply #9 on: February 08, 2018, 10:39:23 pm »
No effects loop yet. I wonder if the fact that I built the input circuit on a daughter board and ran wires to the fist stage has any bearing on this. I used shielded  guitat wire first but it doesn't seem to make any difference.
« Reply #10 on: February 08, 2018, 11:04:32 pm »
Shouldn't be a problem.  I'm sure you checked your wiring on that board?  No bridges when you cut the board?  Are you going to a good ground?  I'm hoping someone else will jump in here! :help:
« Reply #11 on: February 08, 2018, 11:09:20 pm »
Sorry, I thought that was a strip board.
« Reply #12 on: February 08, 2018, 11:18:27 pm »
No worries.lol. I'm sure my lead dress could be better but, this seems so much worse that just a lead dress problem. Like I said, I'll try to draw up a schematic for the circuit and post it in the next day or two.
« Last Edit: February 09, 2018, 07:14:34 am by Captain chunkulus »
Offline SILVERGUN
« Reply #13 on: February 09, 2018, 08:52:38 am »
Input picture
So, you brought the cathode resistor, cap, grid stopper(s)? from the preamp gain stage(s) over to that little board where your input jack is??
If so, where did you come up with that idea?
Ok, I found this in the schematics library....now I get it
« Last Edit: February 09, 2018, 09:15:14 am by SILVERGUN »
« Reply #14 on: February 09, 2018, 09:21:33 am »
Yeah, that's the one.
« Reply #15 on: February 09, 2018, 09:25:54 am »
Like I said, I had it working before but could never completely  get rid of the hum so, I rebuilt the preamp. The power amp is exactly the same as it has always been since I first built it.
« Reply #16 on: February 09, 2018, 09:36:18 am »
Here's a little more info. I'm using a non center tapped tsl100 power transformer, a mercury magnetics super stack output transformer. The bias circuit is from a jcm900 amp. Using 22uf500v caps and 10k 2 watt resister on the power rail from the preamp except for the phase inverter which is tapped separately from the power supply with a 2 watt 22k resister and a 500v 47uf cap on its power rail. Pretty much just like the jvm. Since I'm only using 4 preamp tubes and not 5 like the jvm, there is one less cap and resister on the preamp power rail that the jvm has. The guitar input, preamp are grounded to a ground buss that connects to the speaker ground then to the ground lug on the power jack. The power supply is grounded via the center lug where  the 2 100ohm resister on the heater circuit goes to ground. Don't know if any of this helps or not.
« Reply #17 on: February 09, 2018, 10:04:06 am »
take the speaker outta the loop, ground the preamp buss to the input jack ground tab, which should be chassis ground also, just further away than HT ground
Offline SILVERGUN
« Reply #18 on: February 09, 2018, 10:06:01 am »
This sounds squirl'y. Try to isolate the preamp ground.
The power jack ground should only be connected to the chassis at a point that is very close to where it enters the chassis with it's own separate connection. (in theory)
It is a safety ground only and should not be confused with the circuit ground.
Take a look at the library for some grounding schemes and listen to shooter
Offline SILVERGUN
« Reply #19 on: February 09, 2018, 10:12:43 am »
It looks like you've got some serious wiring faux pas going on there
Whats happening with all of those green wires coming off of the cliff jacks?
« Reply #20 on: February 09, 2018, 10:22:19 am »
The green wire from the board is the -feedback wire going to the 16 ohm tap. The other great wires are going back to the output transformer 4 8 and 16 ohm taps. I just chose green for those runs because I had a lot of green wire laying around.
« Last Edit: February 09, 2018, 11:25:27 am by Captain chunkulus »
Offline SILVERGUN
« Reply #21 on: February 09, 2018, 10:29:19 am »
Some good old hi rez pics all around the inside of the chassis will be very helpful to anyone who is playing along,,,,even Jim
« Reply #22 on: February 09, 2018, 10:44:43 am »
Currently it looks like a rats nest because I've been rewiring stuff. However, I used shielding guitar cable from the input grounded on one end and the high pitched oscillation stoped.
« Reply #23 on: February 09, 2018, 10:57:45 am »
Okay here are some pics. One thing, the sound fades back in when you hit a chord. In other words sounds right but when you stop the hum fades back in almost like a compressor sound.
« Reply #24 on: February 09, 2018, 10:59:02 am »
More pics.
« Reply #25 on: February 09, 2018, 11:00:41 am »
Pics cont.
« Reply #26 on: February 09, 2018, 11:02:29 am »
More.
« Reply #27 on: February 09, 2018, 11:04:47 am »
Last note, all controls work as they should. Resonance, presence, eq. However, the gain pot seems strange,  it should completely mute the sound if turned all the way down but it allows a completely clean guitar sound through when turned off.
« Last Edit: February 09, 2018, 11:07:05 am by Captain chunkulus »
Offline SILVERGUN
« Reply #28 on: February 09, 2018, 12:11:20 pm »
That sounds like a wiring error but without a working schematic we can't tell for sure. There are different ways to make gain controls.
« Reply #29 on: February 09, 2018, 12:22:12 pm »
This is how it's wired.
« Reply #30 on: February 09, 2018, 12:31:27 pm »
Okay, so comming off the 2.2 Meg it goes into the gain circuit then comes back in at the 2nd tube stage.tried to make connections on my phone in red..
« Reply #31 on: February 09, 2018, 12:36:14 pm »
I'm certain that I have stuff wrong.lol. any help from you amazing knowledgeable amp gurus is greatly  appreciated.
Offline SILVERGUN
« Reply #32 on: February 09, 2018, 02:25:03 pm »
Take some time, edit the schematic so it accurately reflects what you have in front of you, and if you can't stay away, just continue looking for wiring errors.
« Reply #33 on: February 09, 2018, 05:04:08 pm »
Is this your basis for your amp;
http://el34world.com/charts/Schematics/files/marshall/Marshall_jvm410%20sch.pdf
have you pulled tubes 1 at a time starting with V1, then 2 then 3 till you only have PA tubes in?
and move the speaker ground out of the preamp :laugh:
« Reply #34 on: February 09, 2018, 05:14:31 pm »
Already moved the speaker ground. Lol. I was using a jcm800 2204 schematic for the grounding schem originally. My original video post however is no longer relevant because I figured out the main issues. #1 shielded guitar cable to the1st stage grounded at 1 end. 2nd had to reverse the two wires on the output transformer.  Now I'm left with just some sort of ground hum and the weird gain pot thing. Yes it's the jvm 410 or jvm210 schematic. I will try to get a modified schematic up over the weekend for what I changed. Haven't tried pulling tubes since after I found the other issues but will give it a try this evening.
« Last Edit: February 09, 2018, 05:18:24 pm by Captain chunkulus »
« Reply #35 on: February 09, 2018, 06:02:02 pm »
it's the jvm 410
the schematic looks more like a EE grads final project trying to impress the teacher than a tube amp :icon_biggrin:
« Reply #36 on: February 09, 2018, 06:20:06 pm »
it's the jvm 410
Right, lol. That's why I'm doing some things different.
« Reply #37 on: February 09, 2018, 06:44:41 pm »
Hey Mr. Latetotheparty....  We were deep into it before you came waltzing along...  Real techs don't need no hi-rez pics!
« Reply #38 on: February 09, 2018, 06:46:37 pm »
it's the jvm 410
Man, I was thinking the same thing!  Although connectors and other details relevant to the layout is kind of nice - but does get cluttered.
« Reply #39 on: February 09, 2018, 06:47:51 pm »
Captain
Just for giggles, try lifting your feedback.
« Reply #40 on: February 09, 2018, 06:56:32 pm »
Captain
I will when I get home this evening. Btw Jim, thanks so much for being patient with me. I love learning about this stuff and building stuff. The first build I did was with my Dad. We built a delux reverb with a full eq. This is my first real serious  build by myself. I taught myself how to read schematics and have been reading lots of books. I have a copy of the tube amp book ( that's where I started) mullard circuits for tube amps and several others. Haven't been doing this very long. I just love it! Tube technology fascinates me.
« Reply #41 on: February 09, 2018, 08:00:22 pm »
Hey I learn something new every time I come here!  This is a cool hobby and this forum is the best place on the planet to learn.  Other than Silvergun and Jojo, and... we are all nice people! :icon_biggrin:
The first modification I ever did was with my dad converting a mono hi-fi tube amp for guitar back in the 60's.  Great memories.  Don't forget to thank Pops for your current obsession!
« Reply #42 on: February 09, 2018, 08:13:09 pm »
Indeed! My dad got me into electronics  when I was about 9 or 10 years old. He used to work for a company called Valley People here in nashville tn. I helped him populate the pc boards as a sub contractor. They didn't know it was a kid building the stuff at home, my dad would pay me like .25 a board. Gain brains, kepex's etc.
« Reply #43 on: February 10, 2018, 08:54:10 am »
Same here, my dad was a recovering alcoholic , he was working with/for Goodwill fixing broke TV's n radios.
he taught me to solder, then shag tubes to the local shop to test, pretty soon I was running test patterns n tweaking color guns
Guess what you HAVE to do in the future :icon_biggrin:
« Reply #44 on: February 10, 2018, 01:36:38 pm »
Captain
Tried the feedback wire, not that. It's really weird, I can turn the gain all the way down and the channel volune as well but I'm still getting signal at the phase inverter.
« Reply #45 on: February 10, 2018, 02:08:03 pm »
I think at this point we need you to draw up a schematic of exactly what you have.  You mentioned that you checked and double checked your wiring and components. We need to see your design.
« Reply #46 on: February 11, 2018, 03:51:06 pm »
Well, it's not really my design. I'm working off of a jvm 410 schematic. Only real changes are plate resister values. Cathode bypass caps, bias voltage circuit and the addition of a dc heater circuit for the first two tubes. This is a one channel amp, no switching or reverb or effects loop as of yet. I can upload a schematic of the jvm with what values I changed and the bias circuit as well as the DC heater circuit.
« Reply #47 on: February 11, 2018, 04:50:43 pm »
Don't know if this helps or not.  :BangHead:
« Reply #48 on: February 11, 2018, 04:54:05 pm »
Pics
« Reply #49 on: February 11, 2018, 04:54:55 pm »
Pics
