September 14, 2026, 11:16:54 pm
Hoffman Amps Forum image Author Topic: 8908 power tubes  (Read 14109 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
8908 power tubes
« on: February 16, 2018, 05:07:47 pm »
Hi everybody !
I have purchased a Traynor amplifier with 8908 power tubes in it. They look like 6BQ5 / EL84 but I can't find specs on the net. The pinout is the same: tha amp was working when I bought it.
Anybody has an idea of the specs ? Power, voltage and so on. The preamp tubes were 5814A (12au7) instead of 12ax7 and it seems to me that the last overhaul has been performed by a tech who used what he had on hand...
Colas
P.S.: call me Alvin.
Re: 8908 power tubes
« Reply #1 on: February 16, 2018, 07:40:39 pm »
6kg6/el509 will replace with a sockets swap. 8908 available on ebay as well...  both 6kg6 and 8908 are 40W plate diss.
8908 tube   6KG6/EL509 tube
Pin 1=G1           Pin 1=G1 (also--Pin 8=G1)
Pin 2=G3           Pin 2=G3 (also--Pin 7=G3)
Pin 3=G2           Pin 3=G2; (also--Pin 6=G2)
Pin 4=cathode    Pin 9=cathode
Pin 5=G1           Pin 8=G1 (also--Pin 1=G1)
Pin 6=G3           Pin 7=G3 (also--Pin 2=G3)
Pin 7=heater      Pin 4=heater
Pin 8=heater      Pin 5=heater
3/8" Plate Cap   1/4" Plate Cap
  • MAKE LOVE NOT WAR
« Reply #2 on: February 16, 2018, 08:00:18 pm »
I don't understand why the 8908 work then if the pinout you gave me is correct because the amplifier I have is wired for two el84 The heaters of the el84 are pins 4 and 5 .  :BangHead:
« Reply #3 on: February 16, 2018, 08:18:31 pm »
8908 are NOVAR socket with a plate cap - not NOVAL socket. perhaps the amp has been rewired for 6KG6 already? 6GK6 has same filament pins as EL84. are you SURE those are NOVAL (EL84/12AX7 type) sockets and not NOVAR? is there a plate cap? if not, maybe it was rewired for 6GM5? 6GM5 datasheet attached.
MAGNOVAL/NOVAR socket.
https://tubedepot.com/products/9-pin-novar-magnoval-socket?gclid=CjwKCAiAn5rUBRA3EiwAUCWb21ERabtLbNIga6rNWGnFxrUFyFZSYdqzQPwtFjF4MUEHLG80VKtc-hoCEUMQAvD_BwE
NOVAL socket.
https://tubedepot.com/products/vintage-9-pin-noval-socket?gclid=CjwKCAiAn5rUBRA3EiwAUCWb23P9cX0L1DdU3Pb5Fv7iHvrqLDc7dv9wVPzAp0KhyjZLo99xKnXGzBoC6w4QAvD_BwE
  • MAKE LOVE NOT WAR
« Reply #4 on: February 16, 2018, 08:37:43 pm »
uffffff, I am lost. Are you trying to tell me that a 8908 won't fit in an el84 socket ? Ok I will try to fit in a 12 ax7 just to see. What is the idea of replacing a 6BQ5 by a 8908 ?
« Reply #5 on: February 16, 2018, 09:16:48 pm »
Post a pic of those 8908 tubes.
« Reply #6 on: February 17, 2018, 07:46:33 am »
Ciao Colas
I've find a link were a guy say he subbet the 8908 with 6LW6
https://groups.google.com/forum/#!topic/rec.radio.amateur.homebrew/XTS1TndfVfA
http://tdsl.duncanamps.com/show.php?des=6LW6
this is from e-bay (a bit expensive  :huh: ) and didn't seem to have a noval or magnoval socket
https://www.ebay.com/itm/8908-TUBES-HY-GAIN-AMATEUR-RADIO-LINEAR-HI-POWER-TUBE-RARE-SET-/263146554910
Are you sure about the number ? Is 8908 designation correct ?
« Last Edit: February 17, 2018, 07:54:18 am by kagliostro »
« Reply #7 on: February 17, 2018, 07:54:24 am »
I think Colas is mistaken about the identification of his tubes. He says they look like EL84/6BQ5s and have the same pin-out.   :dontknow:
« Reply #8 on: February 17, 2018, 08:02:07 am »
I've a tube in my mind that remember an el84 but is a bit larger (and may be have a socket similar to the el84)
but I'm not able to remember the designation label, I only remember that this tube is still manufactured (newly remanufactured, may be by HH)
« Reply #9 on: February 17, 2018, 08:50:34 am »
7189 is a more powerful EL84 and it can be wired the same. It can also be wired a bit differently so you must check the actual wiring before just swapping one for the other.
6973 (I used in my Supro) looks like an EL84 but has a completely different pin-out.
But no way does an 8908 even begin to resemble an EL84. That's why I want Colas to post a pic of the tube he says is an 8908. Maybe we can figure out what he really has.
  • MAKE LOVE NOT WAR
« Reply #10 on: February 17, 2018, 11:30:18 am »
I will post a pic when back to my shop later today. But definitely the picture of the 8908's  taken by Kagliostro doesn't represent the 8908 I have. Mines are identical to EL84's and the pinout is the same: the socket wiring hasn't been modded and the amp is working.
Colas
« Reply #11 on: February 17, 2018, 11:41:55 am »
Waiting for pictures
  • MAKE LOVE NOT WAR
« Reply #12 on: February 17, 2018, 07:43:39 pm »
here are the 8908 pics:
Offline VMS
« Reply #13 on: February 18, 2018, 12:52:20 am »
What are the markings above the 8908?
Looks little like a 6p14p tube
« Last Edit: February 18, 2018, 12:57:15 am by VMS »
« Reply #14 on: February 18, 2018, 03:20:15 am »
8908 is the date code or lot number. they are russian EL84 equivalent.
cyrillic alphabet translation to latin alphabet - 6P14P  is what is marked above the date code.
EDIT: attached bi-lengual datasheet.
« Last Edit: February 18, 2018, 03:25:47 am by DummyLoad »
« Reply #15 on: February 18, 2018, 04:56:45 am »
 :smiley:
Ah, OK, that is a Russian 6П14П (6P14P), a very good substitution for EL84
I can't see well the label on the tube, is 6П14П followed by other caracters ?
Use this to interpret the added characters if present
E (russian E) - long life (5000h and more)
D (russian Д) - ultra long life (10000h and more)
V (russian B) - vibration proof, high reliability
I (russian И) - for impuls mode (high emission of catode)
K (russian K) - vibration proof
R (russian P) - vibration and radiation (nuclear reliability) proof
so 'EV' (rus EB) is 'long life' + 'vibration proof, high reliability' etc
also stamps:
ОТК - standard quality
ВП - military
ОС - ultra stable parameters
« Last Edit: February 18, 2018, 05:19:56 am by kagliostro »
  • MAKE LOVE NOT WAR
« Reply #16 on: February 18, 2018, 08:33:26 am »
Exactly, that's what it is, with russian caracters stamped above. It's the first time I see these tubes. It seems they are hard to find. The amplifier sounds VERY good. In fact it is the best sounding Traynor amp I have ever owned .
Thanks guys !!!
Colas
« Reply #17 on: February 18, 2018, 04:23:29 pm »
I forgot
here the correspondence between our characters and russian characters
http://tdsl.duncanamps.com/cyrillic.php
