September 08, 2026, 11:23:23 am
Hoffman Amps Forum image Author Topic: guitar shielding.  (Read 9914 times)
Offline punkykatt
guitar shielding.
« on: February 17, 2018, 06:44:22 pm »
Hello, Do any of you guitar players shield your strats or teles  body pickup cavities and pick guards with copper foil tape to get rid of EMI noise? Or do you use a Furman  power conditioner? Or both? My band  got  a new venue and both guitars and the bass were wicked loud nasty buzz. We had to use the neck and center pickups or bridge and center pickups together all night to rid the buzz. I have one of those testers you plug in the receptacles to check for ground connection. All tested good.  Any comments/ suggestions are much appreciated.
Re: guitar shielding.
« Reply #1 on: February 17, 2018, 11:29:28 pm »
Originally used by Ritchie Blackmore's tech in his Strats during the first Rainbow tour due to the rainbow lighting rig being fired by SCR's that would make a neon sign sound quiet.  It was called radar paint and the folks below ran with it.  Not cheap but works great.
http://www.stewmac.com/Pickups_and_Electronics/Shielding/Conductive_Shielding_Paint.html
Offline G._Hoffman
« Reply #2 on: February 17, 2018, 11:31:41 pm »
Every electric I build, I shield with shielding paint.  It definitely helps, but isn't a night and day thing in most situations.  On occasion, you'll be in a really bad bar or something and it will help a lot.  Whatever material you use, it won't get rid of the single coil hum because the pickups (obviously) can't be completely shielded.
Gabriel
Offline G._Hoffman
« Reply #3 on: February 17, 2018, 11:35:05 pm »
It's very cheap, if you are shielding enough guitars.  But it doesn't make much sense for just one guitar, though.
By the by, you can just use aluminum foil and spray adhesive.  It works just as well as anything else.
Gabriel
« Reply #4 on: February 18, 2018, 08:29:51 pm »
I shield the bottom of the pickguard with aluminum foil; and the cavity with foil or shielding paint.  I also use the guitarnuts.com method of avoiding ground loops; and separate chassis from signal ground inside the cavity.  The "foil" is the thicker foil from disposable aluminum serving pan lids.
« Last Edit: February 18, 2018, 08:32:30 pm by jjasilli »
Offline punkykatt
« Reply #5 on: February 19, 2018, 07:08:48 pm »
thanks for the replies guys. Much appreciated.
Offline rake
« Reply #6 on: March 04, 2018, 06:43:55 pm »
You also can get aluminum foil duct tape. 2" wide at most big box stores.
HVAC guys use it.
Solid state has no soul........
Offline jeff
  • Need input
« Reply #7 on: March 23, 2018, 08:34:15 pm »
I would say if you are getting zero hum in positions 2 and 4 shielding won't help. If you get a slight hum in 2 and 4 shielding might help with that but 1 3 and 5 will always pick up any stray noise, just the nature of a single coil.
Offline Jennings
« Reply #8 on: June 13, 2019, 06:09:08 am »
I tend to find I focus more on well grounding the electrics, and a good connection between that ground and the bridge/tailpiece ground.  Often the latter is overlooked or inadequate, and seems to be when most of the hum issues I've come across come from.
Offline nandrewjackson
« Reply #9 on: June 20, 2019, 09:50:52 pm »
+1 for the metal HVAC ducting tape
