September 08, 2026, 07:45:16 pm
Hoffman Amps Forum image Author Topic: Hammond AO-63 Question  (Read 8621 times)
« on: February 21, 2018, 11:58:30 am »
I actually found a AO-63 I had stashed away.  This schematic is correct I have attached.  Sluckey did a converion if this, so I know it works.  My question is this amp has inductor input, but has 2 in series.  Looking at them, the seem very small and I cannot seem to find the specs on them.
The 2 are L300 and L301 and my amp is this older version.  The newer versions have 1 inductor and is way bigger than the 2 combined in series on my amp.
My question, are series inductors capable of handling more amperage?
Re: Hammond AO-63 Question
« Reply #1 on: February 21, 2018, 12:11:20 pm »
pretty sure inductors are the same as R's, so series no, in || yes.  I believe more henrys "resist" current change more.
« Reply #2 on: February 21, 2018, 12:14:33 pm »
No, but the total inductance will be the sum of the two chokes, just like putting two resistors in series. Some of the big 4 tube Sunns used two chokes in parallel to double the current handling capacity.
I have the same AO-63 with two small chokes. They are plenty big for that amp. As you already noticed, this is a true choke input power supply filter. You need to stick to the choke input . Otherwise your B+ will be extremely high if you try to put a cap in front of the chokes. That PT puts out 430-0-430 VAC!
Also notice the HT secondary winding has lower voltage taps that feed another rectifier to produce a much lower voltage for the 6GW8 power amp (reverb).
Wha'cha gonna do with it?
« Reply #3 on: February 21, 2018, 01:00:20 pm »
Well, I plan to build a Bogner Extacy since it has AMPEG Tubes.  Don't you love my smart replies?
I built the a Gemeni preamp on the Breadboard and tied it to a Cap input power section with 2 6L6's and it sounded ok.  I pulled out an a 2 henry, 200 ma Choke I had around.
Guess What?  Oh glory be, it is not the Sunn cab.  It is the damn choke input.
OK the cat is out of the bag.  Yes, I have played Sluckeys Hampeg and it has the best clean tone I have ever heard.  I had planned to build an Ampeg.  The Stones used Ampegs on the early 70's when Keef was influences by Graham Parsons and I could hear Tumblin Dice even though I was not G tuned and capo at 4.
That is twangin goodness, great verb and tremolo and just loves an old Broadcaster Bridge PUP.
I have read inductors in series simply increase inductance like resistors when in series.  The chokes look small compared to what I usually look for.  Usually, I prefer the AO-15 that you find in the JR-20 tone cabinet.  Here I can make the 20 watt, 40 watt amp.  20 watts mono, 40 watts stereo.
It is more work than converting an AO-43, but the result is much more flexibility.  It is sort of difficult to reuse the chassis as it is long, very long.
I am wanting to Replace my 62 Bassman that I use in my larger rig along with my modded JTM 45.  I have found all the original components and restored the bassman to its original glory and everytime I take it somewhere it gets wear.  Doesn't make sense to keep gigging it and destroy the appearance.
So I need a new 50ish watt clean, snappin, poppin, twanging, rockin, reverberating, tremolo shaking, Modulation making lovin machine.
« Last Edit: February 21, 2018, 01:07:31 pm by Ed_Chambley »
Online DummyLoad
« Reply #4 on: February 23, 2018, 02:05:23 pm »
can you even get 50W out of a pair of 7591? ...or is 45W with 50W in clipping "close enough?"
« Reply #5 on: February 23, 2018, 08:54:20 pm »
The book values go to 45W.
Which is a lot for a pair of old-rating 6L6.
I don't know why 40W is disappointing.
I do bet I could get 80 Watts... for a few seconds.
_MY_ preference would be to lose the "high gain" aspect of 7591 and go for reliable old 6L6(GC).
« Reply #6 on: February 28, 2018, 11:42:15 am »
I checked a Pair of 6L6GC and they sounded the same when producing clean tone.  Of coures, I have a few 7591's so I will use the up.
« Reply #7 on: February 28, 2018, 11:47:13 am »
Be careful! The bias supply in the AO-63 only puts out -22vdc.
