October 06, 2026, 09:25:08 am
Hoffman Amps Forum image Author Topic: very rapid low frequency motorboating  (Read 10510 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: February 23, 2018, 11:20:47 am »
Hi, it's the first time I get this problem. The amp is a Traynor reverb mate. The prob is like a reversed plate leads: when standby sw. on, even with input shorted to gnd, a loud sound comes out of the amp. But instead of a loud squeal heard with anode leads reversed, it is a loud low frequency very rapid motorboating sound.
WHAT I DID SO FAR:
-replaced all the tubes and checked bias
-disonnected reverb and trem circuits from the turret board and reconnected everything back
-pulled out rev and trem tubes and disconnected the rev tank
-checked out the voltages, all OK
-replaced the 40uF caps feeding the plates and the screens by 80 uF ones
-pulled out V1 : same problem, then checked resitors values at PI, everything's fine
The prob comes either from the PI circuit ( though all voltages are fine there ), from the audio transformer, or from hell :BangHead:
No, I haven't smoked nothing yet...
Thanks, bros
Colas
P.S.: call me Alvin.
Re: very rapid low frequency motorboating
« Reply #1 on: February 23, 2018, 11:27:48 am »
Is this a stock amp?
Have any other mods been done?
I ask because this symptom would be common if you had cascaded gain stages that shared a cathode bypass cap...could be a rookie mistake
  • MAKE LOVE NOT WAR
« Reply #2 on: February 23, 2018, 11:32:58 am »
No other mods than the filtering caps replacement have been performed, the amp is stock. Like I said, the prob appears with only the phase inverter tube and the power tubes connected.
« Reply #3 on: February 23, 2018, 11:34:40 am »
I checked the library for a schematic with no luck.
Have you tried disconnecting NFB? (if it's there)
Offline VMS
« Reply #4 on: February 23, 2018, 11:58:55 am »
Might be one of the decoupling caps:
http://www.geofex.com/ampdbug/mtrboat.htm
« Reply #5 on: February 23, 2018, 11:59:35 am »
  • MAKE LOVE NOT WAR
« Reply #6 on: February 23, 2018, 12:21:11 pm »
I haven't tried to disconnect the nfb (yes it's still there, the amp is stock) but sure I have checked the two .1uF decoupling caps,  I get minus 17V at both of them, exactly the good bias voltage according to the schems I get here, tacked to the back of the top cover of the amp.
I'll perform more tests gee I am fed up with this particular one :cussing:
Thanks buddies !!!
Colas
« Reply #7 on: February 23, 2018, 02:02:34 pm »
WHAT I DID SO FAR:
Thanks, bros
Colas
schematic? pics? soundclip?
« Reply #8 on: February 23, 2018, 02:11:22 pm »
+1 to VMS.  Also checkout Tubenit's troubleshooting procedures & flowcharts.
  • MAKE LOVE NOT WAR
« Reply #9 on: February 23, 2018, 02:26:40 pm »
It is NOT the kind of motorboating due to insufficient filtering capacitance. I am still troubleshooting other options
Thanks.
Coca Colas
« Reply #10 on: February 23, 2018, 03:51:37 pm »
the decoupling caps that VMS is referring to in that link are the power supply B+ caps for the preamp stages. not the coupling caps. e.g. the electrolytic cap(s) for pre-amp power.
« Reply #11 on: February 23, 2018, 09:19:35 pm »
Maybe undo that mod.
Noise coming seemingly from nowhere might be caused in the bias supply, but you give no schematic.  Is it cathode or fixed bias?
  • MAKE LOVE NOT WAR
« Reply #12 on: February 23, 2018, 10:30:51 pm »
I have the schematcs tacked onto the top cover but It's too big to take a clear picture of it. The amp is fixed bias with trem and reverb. I ended up replacing all the coupling caps and the ceramic caps (discs),  some were microphonic. When I was knocking on the cabinet, the amp was starting to hum like hell (I had changed the tubes so that wasn't the issue). Now I can play the amp. The trem is working very well but the reverb is a pain in the....neck. I don't know if the tank is defective but when I reversed the input and output leads, it  works just the same but pretty soon a high squeal feedback takes place and I have to unplug the speakers to stop it quick, the s b switch is too long cutting the sound. When the reverb tube pulled out, the reverb knob acts as a treble knob, seems a problem to me. The Fender reverb circuit with the transformer works better, but the Traynor's tremolo is fantastic.
Colas
Offline VMS
« Reply #13 on: February 24, 2018, 12:31:19 am »
Take two or more pictures, we can put them together then.
« Reply #14 on: February 24, 2018, 12:04:48 pm »
Are you sure that while you were working the amplifier was not infested by something like this?
click >> Haunter
 :l2:
I didn't resisted, sorry :icon_biggrin: :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #15 on: February 25, 2018, 04:35:52 pm »
right on Franco !
